ActiveX 开发指南
相关分类
Delta Property (ActiveX)
2023-1-3 19:05| 发布者: admin| 查看: 1926| 评论: 0|来自: AutoCAD
摘要: 获取直线的增量。
获取直线的增量。
支持的平台:仅窗口
工 务 局:
object.Delta
类型:线
此属性适用的对象。
只读:是的
类型:变体(双精度的三元素数组)
表示线条的 deltaX、deltaY 和 deltaZ 值的三元素数组。
没有额外的评论。
工 务 局:
Sub Example_Delta()
    ' This example adds a line in model space and returns the delta of the new line
    Dim lineObj As AcadLine
    Dim lineDelta As Variant
    Dim startPoint(0 To 2) As Double, endPoint(0 To 2) As Double
    ' Define the start and end points for the line
    startPoint(0) = 1: startPoint(1) = 1: startPoint(2) = 0
    endPoint(0) = 5: endPoint(1) = 5: endPoint(2) = 0
    ' Create the line in model space
    Set lineObj = ThisDrawing.modelSpace.AddLine(startPoint, endPoint)
    ' Display the delta of the new line
    lineDelta = lineObj.Delta
    MsgBox "The delta of the new Line is: " & vbCrLf & _
           "DeltaX: " & lineDelta(0) & vbCrLf & _
           "DeltaY: " & lineDelta(1) & vbCrLf & _
           "DeltaZ: " & lineDelta(2)
Visual LISP:
(defun c:Example_Delta()
    ;; This example adds a line in model space and returns the delta of the new line
    ;; Define the start and end points for the line
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
    ;; Create the line in model space
    (vla-ZoomAll acadObj)
    ;; Display the delta of the new line
    (setq lineDelta (vlax-safearray->list (vlax-variant-value (vla-get-Delta lineObj))))
    (alert (strcat "The delta of the new Line is: "
                   "\nDeltaX: " (rtos (nth 0 lineDelta) 2)
                   "\nDeltaY: " (rtos (nth 1 lineDelta) 2)
                   "\nDeltaZ: " (rtos (nth 2 lineDelta) 2)
GMT+8, 2026-11-29 10:37
