ActiveX 开发指南
相关分类
ColorBookPath Property (ActiveX)
2023-1-3 20:32| 发布者: admin| 查看: 1529| 评论: 0|来自: AutoCAD
摘要: 设置配色系统路径。
设置配色系统路径。
支持的平台:仅窗口
工 务 局:
object.ColorBookPath
类型:首选项文件
此属性适用的对象。
只读:不
类型:字符串
彩色书路径。
没有额外的评论。
工 务 局:
Sub Example_ColorBookPath()
    'This example changes the color book path
    'and then sets it to its original string
    Dim pref As AutoCAD.AcadPreferencesFiles
    Set pref = AcadApplication.Preferences.Files
    Dim defCBPath As String
    Dim changedCBPath As String
    defCBPath = pref.ColorBookPath
    MsgBox "The current color book path is " & defCBPath
    pref.ColorBookPath = "c:\winnt;c:\temp"
    changedCBPath = pref.ColorBookPath
    MsgBox "The changed color book path is " & changedCBPath
    pref.ColorBookPath = defCBPath
Visual LISP:
(defun c:Example_ColorBookPath()
    ;; This example changes the color book path
    ;; and then sets it to its original string
    (setq pref (vla-get-Files (vla-get-Preferences acadObj)))
    (setq defCBPath (vla-get-ColorBookPath pref))
    (alert (strcat "The current color book path is " defCBPath))
    (vla-put-ColorBookPath pref "c:\\winnt;c:\\temp")
    (setq changedCBPath (vla-get-ColorBookPath pref))
    (alert (strcat "The changed color book path is " changedCBPath))
    (vla-put-ColorBookPath pref defCBPath)
GMT+8, 2026-11-11 17:16
