ActiveX 开发指南
相关分类
CenterMarkSize Property (ActiveX)
2023-1-3 20:53| 发布者: admin| 查看: 1824| 评论: 0|来自: AutoCAD
摘要: 指定径向尺寸和直径尺寸的中心标记的大小。
支持的平台:仅窗口
工 务 局:
object.CenterMarkSize
类型:暗径,暗径,暗径大
此属性适用的对象。
只读:不
类型:双
一个正实数,指定中心标记或线条的大小。
此属性的初始值为 0.0900。
如果此属性设置为 。CenterTypeacCenterNone
注意:此属性将覆盖给定维度的 DIMCEN 系统变量的值。
工 务 局:
Sub Example_CenterMarkSize()
    ' This example creates a diametric dimension in model space.
    ' It then changes the type of center for the dimension to
    ' center mark, and adjusts the size of the center mark.
    Dim dimObj As AcadDimDiametric
    Dim chordPoint(0 To 2) As Double
    Dim farChordPoint(0 To 2) As Double
    Dim leaderLength As Double
    ' Define the dimension
    chordPoint(0) = 5#: chordPoint(1) = 3#: chordPoint(2) = 0#
    farChordPoint(0) = 5#: farChordPoint(1) = 5#: farChordPoint(2) = 0#
    leaderLength = 1#
    ' Create the diametric dimension in model space
    Set dimObj = ThisDrawing.ModelSpace.AddDimDiametric(chordPoint, farChordPoint, leaderLength)
    ZoomAll
    ' Change the center type to center mark and set the size of the center mark
    dimObj.CenterType = acCenterMark
    dimObj.CenterMarkSize = 0.1
    dimObj.Update
    MsgBox "The center mark size is: " & dimObj.CenterMarkSize
    dimObj.CenterMarkSize = dimObj.CenterMarkSize * 2
    dimObj.Update
Visual LISP:
(defun c:Example_CenterMarkSize()
    ;; This example creates a diametric dimension in model space.
    ;; It then changes the type of center for the dimension to
    ;; center mark, and adjusts the size of the center mark.
    ;; Define the dimension
    (setq chordPoint (vlax-3d-point 5 3 0)
          farChordPoint (vlax-3d-point 5 5 0)
          leaderLength 1)
    ;; Create the diametric dimension in model space
    (setq dimObj (vla-AddDimDiametric modelSpace chordPoint farChordPoint leaderLength))
    (vla-ZoomAll acadObj)
    ;; Change the center type to center mark and set the size of the center mark
    (vla-put-CenterType dimObj acCenterMark)
    (vla-put-CenterMarkSize dimObj 0.1)
    (vla-Update dimObj)
    (alert (strcat "The center mark size is: " (rtos (vla-get-CenterMarkSize dimObj) 2)))
    (vla-put-CenterMarkSize dimObj (* (vla-get-CenterMarkSize dimObj) 2))
    (vla-Update dimObj)
GMT+8, 2026-11-17 12:33
