ActiveX 开发指南
相关分类
块属性 (ActiveX)
2023-1-3 21:17| 发布者: admin| 查看: 1718| 评论: 0|来自: AutoCAD
摘要: 获取绘图的块集合。
获取绘图的块集合。
支持的平台:仅窗口
工 务 局:
object.Blocks
类型:数据库,文档
此属性适用的对象。
只读:是的
类型:块
绘图的集合。Blocks
没有额外的评论。
工 务 局:
Sub Example_Blocks()
    ' This example first finds the Blocks collection
    ' using the Blocks property. It then adds a new
    ' block to the Blocks collection.
    Dim blkColl As AcadBlocks
    Dim newBlock As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    ' Get the Blocks collection
    Set blkColl = ThisDrawing.Blocks
    ' Define the insertion point for the new block
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    ' Add the new block into the Blocks collection
    Set newBlock = blkColl.Add(insertionPnt, "TEST")
    MsgBox "A block called " & newBlock.name & " has been added to the blocks collection", vbInformation, "Blocks Example"
Visual LISP:
(defun c:Example_Blocks()
    ;; This example first finds the Blocks collection
    ;; using the Blocks property. It then adds a new
    ;; block to the Blocks collection.
    ;; Get the Blocks collection
    (setq blkColl (vla-get-Blocks doc))
    ;; Define the insertion point for the new block
    (setq insertionPnt (vlax-3d-point 0 0 0))
    ;; Add the new block into the Blocks collection
    (setq newBlock (vla-Add blkColl insertionPnt "TEST"))
    (alert (strcat "A block called " (vla-get-Name newBlock) " has been added to the blocks collection."))
GMT+8, 2026-10-27 23:02
