ActiveX 开发指南
相关分类
自动跟踪工具提示属性 (ActiveX)
2023-1-3 21:58| 发布者: admin| 查看: 1837| 评论: 0|来自: AutoCAD
摘要: 切换自动跟踪工具提示的显示。
切换自动跟踪工具提示的显示。
支持的平台:仅窗口
工 务 局:
object.AutoTrackTooltip
类型:首选项起草
此属性适用的对象。
只读:不
类型:布尔
  • True:显示自动跟踪工具提示。
  • False:不显示自动跟踪工具提示。
此属性的初始值为。True
启用此属性后,只要光标位于对齐路径上,用户就会看到工具提示。禁用该属性时,不会显示工具提示。
注意:此属性的值存储在自动贴靠系统变量中。
工 务 局:
Sub Example_AutoTrackToolTip()
    ' This example reads and modifies the preference value that controls
    ' the display of the AutoTrack tooltips.  When finished, this example resets the
    ' preference value back to its original value.
    Dim ACADPref As AcadPreferencesDrafting
    ' Get the drafting preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Drafting
    originalValue = ACADPref.AutoTrackTooltip
    MsgBox "The AutoTrackToolTip preference is set to: " & originalValue
    ' Modify the AutoTrackToolTip preference by toggling the value
    ACADPref.AutoTrackTooltip = Not (originalValue)
    newValue = ACADPref.AutoTrackTooltip
    MsgBox "The AutoTrackToolTip preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.AutoTrackTooltip = originalValue
    MsgBox "The AutoTrackToolTip preference was reset back to: " & originalValue
Visual LISP:
(defun c:Example_AutoTrackToolTip()
    ;; This example reads and modifies the preference value that controls
    ;; the display of the AutoTrack tooltips.  When finished, this example resets the
    ;; preference value back to its original value.
    ;; Get the drafting preferences object
    (setq ACADPref (vla-get-Drafting preferences))
    (setq originalValue (vla-get-AutoTrackTooltip ACADPref))
    (alert (strcat "The AutoTrackToolTip preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the AutoTrackToolTip preference by toggling the value
    (vla-put-AutoTrackTooltip ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-AutoTrackTooltip ACADPref))
    (alert (strcat "The AutoTrackToolTip preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-AutoTrackTooltip ACADPref originalValue)
    (alert (strcat "The AutoTrackToolTip preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 16:48
