指定自动捕捉光圈的大小。 支持的平台:仅窗口 属性值只读:不 类型:长 自动捕捉光圈的大小(以像素为单位)。 言论此属性的初始值为 10。 捕捉对象时,自动捕捉光圈显示在十字准线的中心。仅当启用了自动捕捉标记、磁铁或工具提示时,此选项才可用。 注意:此属性的值存储在 APERTURE 系统变量中。
例子工 务 局: Sub Example_AutoSnapApertureSize()
' This example reads and modifies the preference value that controls
' the size of the AutoSnap aperture. When finished, this example resets
' the preference value back to its original value.
Dim ACADPref As AcadPreferencesDrafting
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.preferences.Drafting
originalValue = ACADPref.AutoSnapApertureSize
MsgBox "The AutoSnapApertureSize preference is: " & originalValue
' Modify the AutoSnapApertureSize preference by setting it to 25
ACADPref.AutoSnapApertureSize = 25
newValue = ACADPref.AutoSnapApertureSize
MsgBox "The AutoSnapApertureSize preference has been set to: " & newValue
' this preference in effect
ACADPref.AutoSnapApertureSize = originalValue
MsgBox "The AutoSnapApertureSize preference was reset back to: " & originalValue
Visual LISP: (vl-load-com)
(defun c:Example_AutoSnapApertureSize()
;; This example reads and modifies the preference value that controls
;; the size of the AutoSnap aperture. When finished, this example resets
;; the preference value back to its original value.
;; Get the drafting preferences object
(setq ACADPref (vla-get-Drafting preferences))
(setq originalValue (vla-get-AutoSnapApertureSize ACADPref))
(alert (strcat "The AutoSnapApertureSize preference is set to: " (itoa originalValue)))
;; Modify the AutoSnapApertureSize preference by setting it to 25
(vla-put-AutoSnapApertureSize ACADPref 25)
(setq newValue (vla-get-AutoSnapApertureSize ACADPref))
(alert (strcat "The AutoSnapApertureSize preference has been set to: " (itoa newValue)))
;; this preference in effect
(vla-put-AutoSnapApertureSize ACADPref originalValue)
(alert (strcat "The AutoSnapApertureSize preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-26 22:41
