指定径向尺寸、引线或引线的箭头类型。 支持的平台:仅窗口 属性值只读:不 类型:枚举acDimArrowheadType
言论此属性的初始值为。acArrowDefault 当您使用 该属性指定要用作自定义箭头的块时,此属性将设置为 。ArrowheadBlockacArrowUserDefined 注意:此属性将覆盖给定维度的 DIMLDRBLK 系统变量的值。
例子工 务 局: Sub Example_ArrowHeadType()
' This example creates a Leader object in model space with an associated Annotation
' and then alters the visible appearance (shape) of its arrowhead
' using the ArrowHeadType property
Dim leaderObj As AcadLeader, MTextObj As AcadMText
Dim points(0 To 8) As Double, insertionPoint(0 To 2) As Double, iTextWidth As Double
Dim leaderType As Integer
Dim annotationObject As Object
Dim textString As String
' Define the new MText object
textString = "Hello, World."
insertionPoint(0) = 5: insertionPoint(1) = 5: insertionPoint(2) = 0
iTextWidth = 2
' Create the MText object in model space
Set MTextObj = ThisDrawing.ModelSpace.AddMText(insertionPoint, iTextWidth, textString)
' Data for Leader
points(0) = 0: points(1) = 0: points(2) = 0
points(3) = 4: points(4) = 4: points(5) = 0
points(6) = 4: points(7) = 5: points(8) = 0
leaderType = acLineWithArrow
' Create the Leader object in model space and Associate new MText object
' with new Leader by making the MText object the annotation for the Leader
Set annotationObject = MTextObj
Set leaderObj = ThisDrawing.ModelSpace.AddLeader(points, annotationObject, leaderType)
' Read and display current arrowhead type
MsgBox "The arrowhead type for this object is: " & leaderObj.ArrowheadType
' Alter the arrowhead type property for this object
leaderObj.ArrowheadType = acArrowBoxBlank
MsgBox "The arrowhead type for this object is now set to: " & leaderObj.ArrowheadType
Visual LISP: (vl-load-com)
(defun c:Example_ArrowHeadType()
;; This example creates a Leader object in model space with an associated Annotation
;; and then alters the visible appearance (shape) of its arrowhead
;; using the ArrowHeadType property
;; Define the new MText object
(setq insertionPoint (vlax-3d-point 5 5 0)
textString "Hello, World."
iTextWidth 2)
;; Create the MText object in model space
(setq MTextObj (vla-AddMText modelSpace insertionPoint iTextWidth textString))
;; Data for Leader
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill points '(0 0 0
4 4 0
4 5 0
(setq leaderType acLineWithArrow)
;; Create the Leader object in model space and Associate new MText object
;; with new Leader by making the MText object the annotation for the Leader
(setq annotationObject MTextObj)
(setq leaderObj (vla-AddLeader modelSpace points annotationObject leaderType))
(vla-ZoomAll acadObj)
;; Read and display current arrowhead type
(alert (strcat "The arrowhead type for this object is: " (itoa (vla-get-ArrowheadType leaderObj))))
;; Alter the arrowhead type property for this object
(vla-put-ArrowheadType leaderObj acArrowBoxBlank)
(alert (strcat "The arrowhead type for this object is now set to: " (itoa (vla-get-ArrowheadType leaderObj))))
GMT+8, 2026-10-26 12:34
