指定要用作尺寸线第二端的自定义箭头的块。 支持的平台:仅窗口 属性值只读:不 类型:字符串 要用作尺寸线第一端箭头的块的名称。 言论注意:此属性覆盖给定维度的 DIMBLK2 系统变量的值。
例子工 务 局: Sub Example_ArrowHead2Block()
' This example creates an aligned dimension object in model space
' and then alters the visible appearance (shape) of the arrowhead
' using the ArrowHeadBlock property.
' Use the ArrowHeadBlock property to set the arrowhead to an existing
' block object containing a custom Circle object
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
Dim BlockName As String
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
ZoomAll
' Set arrowhead type to user-defined to allow
' the use of a block as the new arrowhead
'dimObj.ArrowheadType = acArrowUserDefined
DimPointAngularObj.Arrowhead1Block = "CBlock"
DimPointAngularObj.Arrowhead2Block = "CBlock"
ZoomAll
' Read and display current arrowhead block name
BlockName = DimPointAngularObj.Arrowhead2Block
MsgBox "The arrowhead block name for this object is: " & BlockName
Visual LISP: (vl-load-com)
(defun c:Example_ArrowHead2Block()
;; This example creates an aligned dimension object in model space
;; and then alters the visible appearance (shape) of the arrowhead
;; using the ArrowHeadBlock property.
;; Use the ArrowHeadBlock property to set the arrowhead to an existing
;; block object containing a custom Circle object
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Use the custom block as the new arrowhead, the block must exist in the drawing
(vla-put-Arrowhead1Block DimPointAngularObj "CBlock")
(vla-put-Arrowhead2Block DimPointAngularObj "CBlock")
;; Read and display current arrowhead block name
(setq BlockName (vla-get-Arrowhead2Block DimPointAngularObj))
(alert (strcat "The arrowhead block name for this object is: " BlockName))
GMT+8, 2026-10-26 11:21
