ActiveX 开发指南
相关分类
箭头1块属性 (ActiveX)
2023-1-3 22:38| 发布者: admin| 查看: 1743| 评论: 0|来自: AutoCAD
摘要: 指定要用作尺寸线第一端的自定义箭头的块。
支持的平台:仅窗口
工 务 局:
object.Arrowhead1Block
类型:暗三点角度,暗对齐,暗角,暗弧长度,暗角直径,暗旋转
此属性适用的对象。
只读:不
类型:字符串
要用作尺寸线第一端箭头的块的名称。
注意:此属性覆盖给定维度的 DIMBLK1 系统变量的值。
工 务 局:
Sub Example_ArrowHead1Block()
    ' This example creates an aligned dimension object in model space
    ' and then alters the visible appearance (shape) of the arrowhead
    ' using the ArrowHeadBlock property.
    ' Use the ArrowHeadBlock property to set the arrowhead to an existing
    ' block object containing a custom Circle object
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    Dim BlockName As String
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ZoomAll
    ' Set arrowhead type to user-defined to allow
    ' the use of a block as the new arrowhead
    'dimObj.ArrowheadType = acArrowUserDefined
    DimPointAngularObj.Arrowhead1Block = "CBlock"
    DimPointAngularObj.Arrowhead2Block = "CBlock"
    ZoomAll
    ' Read and display current arrowhead block name
    BlockName = DimPointAngularObj.Arrowhead1Block
    MsgBox "The arrowhead block name for this object is: " & BlockName
Visual LISP:
(defun c:Example_ArrowHead1Block()
    ;; This example creates an aligned dimension object in model space
    ;; and then alters the visible appearance (shape) of the arrowhead
    ;; using the ArrowHeadBlock property.
    ;; Use the ArrowHeadBlock property to set the arrowhead to an existing
    ;; block object containing a custom Circle object
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Use the custom block as the new arrowhead, the block must exist in the drawing
    (vla-put-Arrowhead1Block DimPointAngularObj "CBlock")
    (vla-put-Arrowhead2Block DimPointAngularObj "CBlock")
    ;; Read and display current arrowhead block name
    (setq BlockName (vla-get-Arrowhead1Block DimPointAngularObj))
    (alert (strcat "The arrowhead block name for this object is: " BlockName))
GMT+8, 2026-11-1 10:58
