ActiveX 开发指南
相关分类
区域属性 (ActiveX)
2023-1-3 22:40| 发布者: admin| 查看: 1644| 评论: 0|来自: AutoCAD
摘要: 指定圆弧、圆、椭圆、填充、轻量多段线、折线、区域或平面闭合样条的封闭区域。
支持的平台:仅窗口
工 务 局:
object.Area
类型:椭圆影线LWPolyline折线区域样条曲线
此属性适用的对象。
只读:不,对象;是,对于所有其他对象Circle
类型:
以方形绘图单位指定的对象的面积。
填充对象:
填充的组合区域的总面积。
宽折线:
该区域由宽度的中心定义。
地区:
面积等于区域中所有对象的组合面积。
打开对象,例如圆弧、样条曲线和开放多段线:
计算面积时,就好像一条直线连接起点和终点一样。
工 务 局:
Sub Example_Area()
    ' This example creates a polyline object and
    ' then uses the area property to find the
    ' area of that polyline.
    Dim points(0 To 5) As Double
    Dim plineArea As Double
    ' Establish the points for the Polyline
    points(0) = 3: points(1) = 7
    points(2) = 9: points(3) = 2
    points(4) = 3: points(5) = 5
    ' Create the polyline in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ' Close the polyline and update display of it
    plineObj.Closed = True
    plineObj.Update
    ZoomAll
    ' Get the area of the polyline
    plineArea = plineObj.Area
    MsgBox "The area of the new Polyline is: " & plineArea, vbInformation, "Area Example"
Visual LISP:
(defun c:Example_Area()
    ;; This example creates a polyline object and
    ;; then uses the area property to find the
    ;; area of that polyline.
    ;; Establish the points for the Polyline
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
    (vlax-safearray-fill points '(3 7
				  9 2
				  3 5
    ;; Create the polyline in model space
    (setq plineObj (vla-AddLightWeightPolyline modelSpace points))
    ;; Close the polyline and update display of it
    (vla-put-Closed plineObj :vlax-true)
    (vla-Update plineObj)
    (vla-ZoomAll acadObj)
    ;; Get the area of the polyline
    (setq plineArea (vla-get-Area plineObj))
    (alert (strcat "The area of the new Polyline is: " (rtos plineArea 2)))
GMT+8, 2026-9-11 15:33
