ActiveX 开发指南
相关分类
应用程序属性 (ActiveX)
2023-1-3 22:50| 发布者: admin| 查看: 1882| 评论: 0|来自: AutoCAD
摘要: 获取应用程序对象。
获取应用程序对象。
支持的平台:仅窗口
工 务 局:
object.Application
类型:所有对象
此属性适用的对象。
只读:是的
类型:应用
作为对象所有者的对象。Application
对象表示应用程序的帧控件和路径设置,并提供在对象层次结构中向下导航的方法。Application
发布信息
释放:AutoCAD 2000 至 AutoCAD 2017
  • 此属性不再支持与文件依赖项和文件依赖项对象一起使用。
工 务 局:
Sub Example_Application()
    ' This example creates a line and then uses the
    ' Application property of the line to return the
    ' application name.
    Dim lineObj As AcadLine
    Dim myApp As AcadApplication
    ' Create a new line reference
    startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
    endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0
    lineObj.Update
    ' Return the application for the object
    Set myApp = lineObj.Application
    ' Display the name of the application
    MsgBox "The application name is: " & myApp.name, vbInformation, "Application Example"
Visual LISP:
(defun c:Example_Application()
    ;; This example creates a line and then uses the
    ;; Application property of the line to return the
    ;; application name.
    ;; Create a new line reference
    (setq startPoint (vlax-3d-point 0 0 0)
          endPoint (vlax-3d-point 2 2 0))
    (vla-Update lineObj)
    ;; Return the application for the object
    (setq myApp (vla-get-Application lineObj))
    ;; Display the name of the application
    (alert (strcat "The application name is: " (vla-get-Name myApp)))
GMT+8, 2026-11-28 10:40
