指定三点角度尺寸的角度顶点。 支持的平台:仅窗口 属性值只读:不 类型:变体(双精度的三元素数组) 表示角度折点的 3D 坐标。 言论没有额外的评论。 例子工 务 局: Sub Example_AngleVertex()
' This example creates a Dim3PointAngular object in model space
' and then alters its angle vertex
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double, NewAngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
Dim CurrentVertex As Variant
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
NewAngleVertex(0) = 1: NewAngleVertex(1) = 1: NewAngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Display current vertex
CurrentVertex = DimPointAngularObj.AngleVertex
MsgBox "The angle vertex of the new object is set to:" & vbCrLf & _
CurrentVertex(0) & vbCrLf & _
CurrentVertex(1) & vbCrLf & _
CurrentVertex(2)
' Alter vertex setting for this object
DimPointAngularObj.AngleVertex = NewAngleVertex
' Display new vertex settings
MsgBox "The angle vertex of the object has been reset to:" & vbCrLf & _
CurrentVertex(2)
Visual LISP: (vl-load-com)
(defun c:Example_AngleVertex()
;; This example creates a Dim3PointAngular object in model space
;; and then alters its angle vertex
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 2 5 0)
NewAngleVertex (vlax-3d-point 1 1 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Display current vertex
(setq CurrentVertex (vla-get-AngleVertex DimPointAngularObj))
(alert (strcat "The angle vertex of the new object is set to:\n"
(rtos (vlax-safearray-get-element (vlax-variant-value CurrentVertex) 0) 2) "\n"
(rtos (vlax-safearray-get-element (vlax-variant-value CurrentVertex) 1) 2) "\n"
(rtos (vlax-safearray-get-element (vlax-variant-value CurrentVertex) 2) 2)))
;; Alter vertex setting for this object
(vla-put-AngleVertex DimPointAngularObj NewAngleVertex)
;; Display new vertex settings
(alert (strcat "The angle vertex of the object has been reset to:\n"
GMT+8, 2026-9-18 23:12
