指定角度尺寸的单位格式。 支持的平台:仅窗口 属性值只读:不 类型:枚举acAngleUnits
言论此属性的初始值为。acDegrees 注意:此属性覆盖给定维度的 DIMAUNIT 系统变量的值。
例子工 务 局: Sub Example_AngleFormat()
' This example creates a Dim3PointAngular object in model space
' and sets its Angle Format to some common values
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Cycle through some common angle formats
DimPointAngularObj.AngleFormat = acDegreeMinuteSeconds
MsgBox "The angle format of the new Dim3PointAngular object is now set to degree/minute/second"
DimPointAngularObj.AngleFormat = acGrads
MsgBox "The angle format of the new Dim3PointAngular object is now set to grads"
DimPointAngularObj.AngleFormat = acRadians
MsgBox "The angle format of the new Dim3PointAngular object is now set to radians"
Visual LISP: (vl-load-com)
(defun c:Example_AngleFormat()
;; This example creates a Dim3PointAngular object in model space
;; and sets its Angle Format to some common values
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Cycle through some common angle formats
(vla-put-AngleFormat DimPointAngularObj acDegreeMinuteSeconds)
(alert "The angle format of the new Dim3PointAngular object is now set to degree/minute/second.")
(vla-put-AngleFormat DimPointAngularObj acGrads)
(alert "The angle format of the new Dim3PointAngular object is now set to grads.")
(vla-put-AngleFormat DimPointAngularObj acRadians)
(alert "The angle format of the new Dim3PointAngular object is now set to radians.")
GMT+8, 2026-10-30 01:35
