指定禁止显示交替容差值中的尾随零。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。False 注意:此属性覆盖给定维度的 DIMALTTZ 系统变量的值。
例子工 务 局: Sub Example_AltToleranceSuppressTrailingZeros()
' uses AltToleranceSuppressTrailingZeros to toggle the display of trailing zeros
' in the alternate dimension tolerance display
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 7: point2(1) = 5: point2(2) = 0
' Set up alternate unit tolerance display
dimObj.AltUnits = True
dimObj.ToleranceDisplay = acTolLimits
Toggle:
Select Case MsgBox("Press OK to toggle the display of trailing zeros in the alternate dimension tolerance", vbOKCancel)
Case vbOK
' Toggle the display of trailing zeros for the alternate dimension tolerance value
dimObj.AltToleranceSuppressTrailingZeros = Not (dimObj.AltToleranceSuppressTrailingZeros)
Case vbCancel
Exit Sub
End Select
GoTo Toggle
Visual LISP: (vl-load-com)
(defun c:Example_AltToleranceSuppressTrailingZeros()
;; uses AltToleranceSuppressTrailingZeros to toggle the display of trailing zeros
;; in the alternate dimension tolerance display
;; Define the dimension
point2 (vlax-3d-point 7 5 0)
;; Set up alternate unit tolerance display
(vla-put-AltUnits dimObj :vlax-true)
(vla-put-ToleranceDisplay dimObj acTolLimits)
(vla-ZoomAll acadObj)
;; Toggle the display of trailing zeros for the alternate dimension tolerance value
(vla-put-AltToleranceSuppressTrailingZeros dimObj (if (= (vla-get-AltToleranceSuppressTrailingZeros dimObj) :vlax-true) :vlax-false :vlax-true))
(alert "Suppression of trailing zeros in the alternate dimension tolerance toggled.")
;; Toggle the display of trailing zeros for the alternate dimension tolerance value back to previous state
(alert "Suppression of trailing zeros in the alternate dimension tolerance toggled back.")
GMT+8, 2026-11-19 06:08
