ActiveX 开发指南
相关分类
AltSuppressLeadingZeros Property (ActiveX)
2023-1-3 23:25| 发布者: admin| 查看: 1743| 评论: 0|来自: AutoCAD
摘要: 指定禁止显示备用维度值中的前导零。
指定禁止显示备用维度值中的前导零。
支持的平台:仅窗口
工 务 局:
object.AltSuppressLeadingZeros
类型:暗对齐,暗弧长度,暗径,暗坐标,暗径,暗径大,暗心旋转
此属性适用的对象。
只读:不
类型:布尔
  • True:隐含交替尺寸中的前导零。例如,0.5000 变为 .5000。
  • False:不隐含交替尺寸中的前导零。
此属性的初始值为。False
注意:此属性将覆盖给定维度的 DIMALTZ 系统变量的值。
工 务 局:
Sub Example_AltSuppressLeadingZeros()
   ' uses AltSuppressLeadingZeros to toggle the display of leading zeros
   ' in the alternate dimension display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 5.01: point2(1) = 5: point2(2) = 0
    ' Enable alternate unit display
    dimObj.AltUnits = True
Toggle:
    Select Case MsgBox("Press OK to toggle the display of leading zeros in the alternate dimension", vbOKCancel)
        Case vbOK
            ' Toggle the display of leading zeros for the alternate dimension value
            dimObj.AltSuppressLeadingZeros = Not (dimObj.AltSuppressLeadingZeros)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
Visual LISP:
(defun c:Example_AltSuppressLeadingZeros()
    ;; uses AltSuppressLeadingZeros to toggle the display of leading zeros
    ;; in the alternate dimension display
    ;; Define the dimension
          point2 (vlax-3d-point 5.01 5 0)
    ;; Set up alternate unit tolerance display
    (setq originalValue (vla-get-AltSuppressLeadingZeros dimObj))
    (vla-put-AltUnits dimObj :vlax-true)
    (vla-ZoomAll acadObj)
    (alert "Toggling the display of leading zeros in the alternate dimension.")
    ;; Toggle the display of leading zeros for the alternate dimension tolerance value
    (vla-put-AltSuppressLeadingZeros dimObj (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-AltSuppressLeadingZeros dimObj))
    (alert "Toggling the display of leading zeros in the alternate dimension to original value.")
    (vla-put-AltSuppressLeadingZeros dimObj (if (= newValue :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-10-27 13:25
