ActiveX 开发指南
相关分类
ADCInsertUnitsDefaultSource Property (ActiveX)
2023-1-3 23:50| 发布者: admin| 查看: 2176| 评论: 0|来自: AutoCAD
摘要: 确定在设计中心中对未指定插入单位的源图形的对象自动使用的单位。
支持的平台:仅窗口
工 务 局:
object.ADCInsertUnitsDefaultSource
类型:首选项用户
此属性适用的对象。
只读:不
类型:枚举acInsertUnits
  • acInsertUnitsAngstroms
  • acInsertUnitsAstronomicalUnits
  • acInsertUnitsCentimeters
  • acInsertUnitsDecameters
  • acInsertUnitsDecimeters
  • acInsertUnitsFeet
  • acInsertUnitsGigameters
  • acInsertUnitsHectometers
  • acInsertUnitsInches
  • acInsertUnitsKilometers
  • acInsertUnitsLightYears
  • acInsertUnitsMeters
  • acInsertUnitsMicroinches
  • acInsertUnitsMicrons
  • acInsertUnitsMiles
  • acInsertUnitsMillimeters
  • acInsertUnitsMils
  • acInsertUnitsNanometers
  • acInsertUnitsParsecs
  • acInsertUnitsUnitless
  • acInsertUnitsUSSurveyFeet
  • acInsertUnitsUSSurveyInch
  • acInsertUnitsUSSurveyMile
  • acInsertUnitsUSSurveyYard
  • acInsertUnitsYards
此属性的初始值为。acInsertUnitsUnitless
注意:此属性的值存储在 INSUNITSDEFSOURCE 系统变量中。
工 务 局:
Sub Example_ADCInsertUnitsDefaultSource()
    ' This example reads and modifies the ADCInsertUnitsDefaultSource
    ' preference value.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesUser
    Dim originalValue As Integer, newValue As Integer
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Application.preferences.User
    originalValue = ACADPref.ADCInsertUnitsDefaultSource
    MsgBox "The ADCInsertUnitsDefaultSource preference is set to: " & originalValue
    ' Modify the ADCInsertUnitsDefaultSource preference by toggling the value
    ACADPref.ADCInsertUnitsDefaultSource = acInsertUnitsMillimeters
    MsgBox "The ADCInsertUnitsDefaultSource preference has been set to: " & ACADPref.ADCInsertUnitsDefaultSource
    ACADPref.ADCInsertUnitsDefaultSource = originalValue
    MsgBox "The ADCInsertUnitsDefaultSource preference was reset back to: " & originalValue
Visual LISP:
(defun c:Example_ADCInsertUnitsDefaultSource()
    ;; This example reads and modifies the ADCInsertUnitsDefaultSource
    ;; preference value.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the user preferences object
    (setq pref (vla-get-Preferences acadObj))
    (setq user (vla-get-User pref))
    (setq originalValue (vla-get-ADCInsertUnitsDefaultSource user))
    (alert (strcat "The ADCInsertUnitsDefaultSource preference is set to: " (itoa originalValue)))
    ;; Modify the ADCInsertUnitsDefaultSource preference by toggling the value
    (vla-put-ADCInsertUnitsDefaultSource user acInsertUnitsMillimeters)
    (alert (strcat "The ADCInsertUnitsDefaultSource preference has been set to: " (itoa (vla-get-ADCInsertUnitsDefaultSource user))))
    ;; Restore the preference back to its original value
    (vla-put-ADCInsertUnitsDefaultSource user originalValue)
    (alert (strcat "The ADCInsertUnitsDefaultSource preference was restored back to: " (itoa originalValue)))
GMT+8, 2026-11-25 17:12
