在图纸空间和模型空间之间切换活动空间。 支持的平台:仅窗口 属性值只读:不 类型:枚举acActiveSpace
言论对于模型空间浮动视口,此值设置为 。即使您能够编辑模型,从技术上讲,您仍然处于图纸空间中。acPaperSpace 有关此属性的详细信息,请参阅对象。PViewport 注意:此属性的值存储在 TILEMODE 系统变量中。
例子工 务 局: Sub Example_ActiveSpace()
' This example toggles the ActiveSpace property from
' paper space to model space.
' Display the current setting for TILEMODE
MsgBox "TILEMODE = " & ThisDrawing.ActiveSpace, vbInformation, "ActiveSpace Example"
' Changes active document to paper space
ThisDrawing.ActiveSpace = acPaperSpace
' Changes active document to model space
ThisDrawing.ActiveSpace = acModelSpace
Visual LISP: (vl-load-com)
(defun c:Example_ActiveSpace()
;; This example toggles the ActiveSpace property from
;; paper space to model space.
;; Display the current setting for TILEMODE
(alert (strcat "TILEMODE = " (itoa (vla-get-ActiveSpace doc))))
;; Changes active document to paper space
(vla-put-ActiveSpace doc acPaperSpace)
;; Changes active document to model space
(vla-put-ActiveSpace doc acModelSpace)
GMT+8, 2026-11-13 05:23
