ActiveX 开发指南
相关分类
ActivePViewport Property (ActiveX)
2023-1-4 00:00| 发布者: admin| 查看: 1817| 评论: 0|来自: AutoCAD
摘要: 指定图形的活动图纸空间视口。
指定图形的活动图纸空间视口。
支持的平台:仅窗口
工 务 局:
object.ActivePViewport
类型:文档
此属性适用的对象。
只读:不
类型:光伏港
活动的图纸空间视口。
必须使用此属性将视区设置为活动状态,然后才能看到对视区的任何更改。
工 务 局:
Sub Example_ActivePViewport()
    Dim newPViewport As AcadPViewport
    Dim height As Double
    Dim width As Double
    height = 5#
    width = 5#
    centerPoint(0) = 5#: centerPoint(1) = 5#: centerPoint(2) = 0#
    ' Create a paper space Viewport object
    ThisDrawing.ActiveSpace = acPaperSpace
    Set newPViewport = ThisDrawing.PaperSpace.AddPViewport(centerPoint, width, height)
    ZoomAll
    newPViewport.DISPLAY (True)
    ' Before making a paper space Viewport active,
    ' the mspace property needs to be True
    ThisDrawing.mspace = True
    ThisDrawing.ActivePViewport = newPViewport
Visual LISP:
(defun c:Example_ActivePViewport()
    (setq centerPoint (vlax-3d-point 5 5 0)
          height 5.0
          width 5.0)
    ;; Create a paper space Viewport object
    (vla-put-ActiveSpace doc acPaperSpace)
    (setq paperSpace (vla-get-PaperSpace doc))
    (setq newPViewport (vla-AddPViewport paperSpace centerPoint width height))
    (vla-ZoomAll acadObj)
    (vla-Display newPViewport :vlax-true)
    ;; Before making a paper space Viewport active,
    ;; the mspace property needs to be True
    (vla-put-MSpace doc :vlax-true)
    (vla-put-ActivePViewport doc newPViewport)
GMT+8, 2026-11-20 19:28
