指定活动文档(图形文件)。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_ActiveDocument()
Dim activeDoc As AcadDocument
' Returns current document in AutoCAD
Set activeDoc = ThisDrawing.Application.ActiveDocument
MsgBox "The active document is: " & activeDoc.name, vbInformation, "ActiveDocument Example"
Visual LISP: (vl-load-com)
(defun c:Example_ActiveDocument()
;; Returns current document in AutoCAD
(setq activeDoc (vla-get-ActiveDocument acadObj))
(alert (strcat "The active document is: " (vla-get-Name activeDoc)))
GMT+8, 2026-10-27 22:21
