指定活动标注样式。 支持的平台:仅窗口 言论此样式将应用于所有新创建的维度。若要更改现有维度上的样式,请使用属性。StyleName 要控制当前文档覆盖的设置,请使用尺寸标注系统变量。有关尺寸标注系统变量的列表,请参见 AutoCAD 文档中的“系统变量”。 更改尺寸标注系统变量时,实际上是在为活动标注样式设置文档覆盖。您不会更改活动标注样式本身。若要更改给定标注样式的设置,请使用该方法。此方法从文档、维度或其他维度样式复制维度样式配置,包括替代。CopyFrom 通过 AutoCAD 用户界面创建的尺寸是使用活动标注样式和所有文档覆盖创建的。通过 ActiveX 创建的维度仅使用活动维度样式创建。若要使通过 ActiveX 创建的维度采用文档替代,请使用该方法将维度样式从文档复制到活动维度样式。此过程会将所有现有替代复制到活动标注样式中。CopyFrom 例子工 务 局: Sub Example_ActiveDimStyle()
' This example returns the current dimension style
' and then sets a new style.
' Finally, it returns the style to the previous setting.
Dim newDimStyle As AcadDimStyle
Dim currDimStyle As AcadDimStyle
' Return current dimension style of active document
Set currDimStyle = ThisDrawing.ActiveDimStyle
MsgBox "The current dimension style is " & currDimStyle.name, vbInformation, "ActiveDimStyle Example"
' Create a dimension style and makes it current
Set newDimStyle = ThisDrawing.DimStyles.Add("TestDimStyle")
ThisDrawing.ActiveDimStyle = newDimStyle ' set current dimension style to newDimStyle
MsgBox "The new dimension style is " & newDimStyle.name, vbInformation, "ActiveDimStyle Example"
' Reset the dimension style to its previous setting
ThisDrawing.ActiveDimStyle = currDimStyle
MsgBox "The dimension style is reset to " & currDimStyle.name, vbInformation, "ActiveDimStyle Example"
Visual LISP: (vl-load-com)
(defun c:Example_ActiveDimStyle()
;; This example returns the current dimension style
;; and then sets a new style.
;; Finally, it returns the style to the previous setting.
;; Get the current dimension style of the active document
(setq currDimStyle (vla-get-ActiveDimStyle doc))
(alert (strcat "The current dimension style is " (vla-get-Name currDimStyle)))
;; Create a dimension style and make it current
(setq dimStyles (vla-get-DimStyles doc))
(setq newDimStyle (vla-Add dimStyles "TestDimStyle"))
(vla-put-ActiveDimStyle doc newDimStyle) ;; set current dimension style to newDimStyle
(alert (strcat "The new dimension style is " (vla-get-Name newDimStyle)))
;; Restore the previously active dimension style
(vla-put-ActiveDimStyle doc currDimStyle)
(alert (strcat "The dimension style is restored to " (vla-get-Name currDimStyle)))
GMT+8, 2026-10-26 17:28
