ActiveX 开发指南
相关分类
卸载方法 (ActiveX)
2023-1-4 00:42| 发布者: admin| 查看: 1656| 评论: 0|来自: AutoCAD
摘要: 卸载菜单组或外部引用。
卸载菜单组或外部引用。
支持的平台:仅窗口
工 务 局:
object.Unload
类型:外部引用,菜单组
此方法适用的对象。
返回值(RetVal)
无返回值。
外部参照:从图形中卸载对象 (外部参照) 时,图形打开速度更快,占用的内存更少。不显示已卸载的外部参照,并且与外部参照相关的符号表信息不显示在图形中。但是,所有信息都可以通过使用该方法重新加载外部参照来恢复。ExternalReferenceReload
要卸载外部参照,必须卸载定义外部参照的块。例如,以下 VBA 代码行卸载存储在变量中的外部引用:xrefInserted
ThisDrawing.Blocks.Item(xrefInserted.name).Unload
菜单组:从图形中卸载菜单组时,对该组中的菜单和工具栏的任何参照都将变为无效。在卸载菜单组之前,请始终删除或设置为对要卸载的菜单组中的工具栏和菜单的任何引用。NULL
工 务 局:
Sub Example_Unload()
    On Error GoTo ERRORHANDLER
    ' Define external reference to be inserted
    Dim xrefHome As AcadBlock
    Dim xrefInserted As AcadExternalReference
    Dim insertionPnt(0 To 2) As Double
    Dim PathName As String
    insertionPnt(0) = 1
    insertionPnt(1) = 1
    insertionPnt(2) = 0
    PathName = "c:/AutoCAD/sample/City map.dwg"
    ' Add the external reference
    Set xrefInserted = ThisDrawing.ModelSpace. _
            AttachExternalReference(PathName, "XREF_IMAGE", _
            insertionPnt, 1, 1, 1, 0, False)
    ZoomAll
    MsgBox "The external reference is attached."
    ' Unload the external reference definition
    MsgBox "The external reference is unloaded."
    Exit Sub
ERRORHANDLER:
    MsgBox Err.Description
Visual LISP:
(defun c:Example_Unload()
    ;; Define external reference to be inserted
    (setq insertionPnt (vlax-3d-point 1 1 0)
          pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
    ;; Add the external reference to the block
    (setq xrefInserted (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" insertionPnt 1 1 1 0 :vlax-false))
    (vla-ZoomAll acadObj)
    (alert "The external reference is attached.")
    ;; Unload the external reference definition
    (vla-Unload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE"))
    (vla-Regen doc :vlax-true)
    (alert "The external reference is unloaded.")
    ;; Reload the external reference definition
    (vla-Reload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE"))
    (alert "The external reference is reloaded.")
GMT+8, 2026-11-12 08:21
