ActiveX 开发指南
相关分类
SetSnapCamcing Method (ActiveX)
2023-1-4 01:28| 发布者: admin| 查看: 1849| 评论: 0|来自: AutoCAD
摘要: 设置视区的捕捉间距。
设置视区的捕捉间距。
支持的平台:仅窗口
工 务 局:
object.SetSnapSpacing XSpacing, YSpacing
类型:光伏端口,视口
此方法适用的对象。
XS间距
访问:仅输入
类型:双
X轴的捕捉间距。
Y间距
访问:仅输入
类型:双
Y轴的捕捉间距。
返回值(RetVal)
无返回值。
X和Y间距的初始值为 1.0000。
此值也由 SNAPUNIT 系统变量控制。
工 务 局:
Sub Example_SetSnapSpacing()
    ' This example finds the current Snap spacing and changes it.
    ' Find the current active viewport
    Dim viewportObj As AcadViewport
    Set viewportObj = ThisDrawing.ActiveViewport
    ' Turn on Snap mode and reset the viewport.
    viewportObj.SnapOn = True
    ThisDrawing.ActiveViewport = viewportObj
    ' Find the current Snap spacing
    Dim XSpacing As Double
    Dim YSpacing As Double
    viewportObj.GetSnapSpacing XSpacing, YSpacing
    MsgBox "X =" & XSpacing & ", Y =" & YSpacing, Title:="SetSnapSpacing Example"
    ' Change the Snap spacing
    XSpacing = XSpacing * 0.5
    YSpacing = YSpacing * 0.5
    viewportObj.SetSnapSpacing XSpacing, YSpacing
Visual LISP:
(defun c:Example_SetSnapSpacing()
    ;; This example finds the current Snap spacing, and changes that spacing.
    ;; Find the current active viewport
    (setq viewportObj (vla-get-ActiveViewport doc))
    ;; Turn on Snap spacing and reset the viewport.
    (vla-put-SnapOn viewportObj :vlax-true)
    (vla-put-ActiveViewport doc viewportObj)
    ;; Find the current Snap spacing
    (vla-GetSnapSpacing viewportObj 'XSpacing 'YSpacing)
    (alert (strcat "X =" (rtos XSpacing 2) ", Y =" (rtos YSpacing 2)))
    ;; Change the Snap spacing
    (vla-SetSnapSpacing viewportObj (* XSpacing 0.5) (* YSpacing 0.5))
GMT+8, 2026-10-27 21:08
