设置样条曲线的拟合点。 支持的平台:仅窗口 签名工 务 局: object.SetFitPoint Index, Value
返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_SetFitPoint()
' This example creates a spline object in model space.
' It then finds the coordinates of the first fit point
' and changes that value.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
' Display the coordinates of the first fit point
Dim fitPoint As Variant
fitPoint = splineObj.GetFitPoint(0)
MsgBox "Fit point 1 is at " & fitPoint(0) & ", " & fitPoint(1) & ", " & fitPoint(2), , "SetFitPoint Example"
' Change the coordinates of the first fit point
fitPoint(0) = 0: fitPoint(1) = 3: fitPoint(2) = 0
splineObj.SetFitPoint 0, fitPoint
splineObj.Update
MsgBox "Fit point 1 is now at " & fitPoint(0) & ", " & fitPoint(1) & ", " & fitPoint(2), , "SetFitPoint Example"
Visual LISP: (vl-load-com)
(defun c:Example_SetFitPoint()
;; This example creates a spline object in model space.
;; It then finds the coordinates of the first fit point
;; and changes that value.
;; Create the spline
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(1 1 0
5 5 0
10 0 0
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Display the coordinates of the first fit point
(setq fitPoint (vlax-variant-value (vla-GetFitPoint splineObj 0)))
(alert (strcat "Fit point 1 is at " (rtos (vlax-safearray-get-element fitPoint 0) 2) ", "
(rtos (vlax-safearray-get-element fitPoint 1) 2) ", "
(rtos (vlax-safearray-get-element fitPoint 2) 2)))
;; Change the coordinates of the first fit point
(setq fitPoint (vlax-3d-point 0 3 0))
(vla-SetFitPoint splineObj 0 fitPoint)
(vla-Update splineObj)
(setq fitPoint (vlax-variant-value fitPoint))
(alert (strcat "Fit point 1 is now at " (rtos (vlax-safearray-get-element fitPoint 0) 2) ", "
GMT+8, 2026-10-31 21:22
