ActiveX 开发指南
相关分类
SetCellClass Method (ActiveX)
2023-1-4 03:12| 发布者: admin| 查看: 2035| 评论: 0|来自: AutoCAD
摘要: 设置单元格样式的类。
设置单元格样式的类。
支持的平台:仅窗口
工 务 局:
object.SetCellClass StringCellStyle, cellClass
类型:表格样式
此方法适用的对象。
字符串单元格样式
访问:仅输入
类型:字符串
单元格样式名称。
细胞类
访问:仅输入
类型:整数
单元格样式类。
返回值(RetVal)
无返回值。
没有额外的评论。
工 务 局:
Sub Example_CellClass()
    ' the style classes and formatting.
    Dim dictObj As AcadDictionary
    ' Create the custom TableStyle object in the dictionary
    Dim keyName As String
    Dim className As String
    Dim customObj As IAcadTableStyle
    keyName = "NewStyle"
    className = "AcDbTableStyle"
    Set customObj = dictObj.AddObject(keyName, className)
    customObj.Name = "NewStyle"
    customObj.Description = "New Style for My Tables"
    customObj.CreateCellStyle ("NewTestStyle")
    Dim cellTestFormat As String
    customObj.SetCellClass "NewTestStyle", 4
    customObj.SetRotation "NewTestStyle", 8.4
    MsgBox "The cell class is " & customObj.GetCellClass("NewTestStyle") & _
           " the cell rotation is " & customObj.GetRotation("NewTestStyle")
Visual LISP:
(defun c:Example_CellClass()
    ;; the style classes and formatting.
    (setq dictObj (vla-Item dictionaries "acad_tablestyle"))
    ;; Create the custom TableStyle object in the dictionary
    (setq keyName "NewStyle"
          className "AcDbTableStyle")
    (setq customObj (vla-AddObject dictObj keyName className))
    (vla-put-Name customObj "NewStyle")
    (vla-put-Description customObj "New Style for My Tables")
    (vla-CreateCellStyle customObj "NewTestStyle")
    (vla-SetCellClass customObj "NewTestStyle" 4)
    (vla-SetRotation customObj "NewTestStyle" 8.4)
    (alert (strcat "The cell class is " (itoa (vla-GetCellClass customObj "NewTestStyle"))
                   " and the cell rotation is " (rtos (vla-GetRotation customObj "NewTestStyle") 2) "."
GMT+8, 2026-10-28 13:17
