ActiveX 开发指南
相关分类
SetBulge Method (ActiveX)
2023-1-4 03:18| 发布者: admin| 查看: 1994| 评论: 0|来自: AutoCAD
摘要: 设置给定索引处折线的凸起。
设置给定索引处折线的凸起。
支持的平台:仅窗口
工 务 局:
object.SetBulge Index, Value
类型:长线,折线
此方法适用的对象。
指数
访问:仅输入
类型:长
要设置的顶点的索引位置。第一个顶点是索引 0。
价值
访问:仅输入
类型:双
给定索引处顶点的凸起值。
返回值(RetVal)
无返回值。
折线:如果折线属性不是,则此方法将失败。TypeacSimplePoly
凸起是所选顶点与折线顶点列表中的下一个顶点之间的弧的包含角度的 1/4 的切线。负凸起值表示弧从所选顶点顺时针移动到下一个顶点。凸起 0 表示直线段,凸起 1 表示半圆。
工 务 局:
Sub Example_SetBulge()
    ' This example creates a lightweight polyline in model space.
    ' It then finds and changes the bulge for a given segment.
    Dim points(0 To 11) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1
    points(2) = 1: points(3) = 2
    points(4) = 2: points(5) = 2
    points(6) = 3: points(7) = 2
    points(8) = 4: points(9) = 4
    points(10) = 4: points(11) = 1
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ZoomAll
    ' Find the bulge of the third segment
    Dim currentBulge As Double
    currentBulge = plineObj.GetBulge(3)
    MsgBox "The bulge for the third segment is " & plineObj.GetBulge(3), , "SetBulge Example"
    ' Change the bulge of the third segment
    plineObj.SetBulge 3, -0.5
    plineObj.Update
    MsgBox "The bulge for the third segment is now " & plineObj.GetBulge(3), , "SetBulge Example"
Visual LISP:
(defun c:Example_SetBulge()
    ;; This example creates a lightweight polyline in model space.
    ;; It then finds and changes the bulge for a given segment.
    ;; Define the 2D polyline points
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 11)))
    (vlax-safearray-fill points '(1 1
                                  1 2
                                  2 2
                                  3 2
                                  4 4
                                  4 1
    ;; Create a lightweight Polyline object in model space
    (setq plineObj (vla-AddLightWeightPolyline modelSpace points))
    (vla-ZoomAll acadObj)
    ;; Find the bulge of the third segment
    (setq currentBulge (vla-GetBulge plineObj 3))
    (alert (strcat "The bulge for the third segment is " (rtos (vla-GetBulge plineObj 3) 2)))
    ;; Change the bulge of the third segment
    (vla-SetBulge plineObj 3 -0.5)
    (vla-Update plineObj)
    (alert (strcat "The bulge for the third segment is now " (rtos (vla-GetBulge plineObj 3) 2)))
GMT+8, 2026-10-27 03:48
