再生整个图形并重新计算所有对象的屏幕坐标和视图分辨率。 支持的平台:仅窗口 签名工 务 局: object.Regen WhichViewports
返回值(RetVal)无返回值。 言论Regen还会重新索引图形数据库,以获得最佳显示效果和更好的对象选择性能。 例子工 务 局: Sub Example_Regen()
' The following example regenerates the complete drawing
' The following example regenerates the active viewport in the current drawing
ThisDrawing.Regen acActiveViewport
Visual LISP: (vl-load-com)
(defun c:Example_Regen()
;; The following example regenerates the complete drawing
;; The following example regenerates the active viewport in the current drawing
(vla-Regen doc acActiveViewport)
GMT+8, 2026-11-18 01:07
