返回已设置的自定义属性字段的数目。 支持的平台:仅窗口 返回值(RetVal)类型:长 已为图形设置的自定义特性字段的数目。 言论没有额外的评论。 例子工 务 局: Sub Example_NumCustomInfo()
' This example shows how to access drawing properties
' Add and display standard properties
ThisDrawing.SummaryInfo.Author = "John Doe"
ThisDrawing.SummaryInfo.Comments = "Includes all ten levels of Building Five"
ThisDrawing.SummaryInfo.HyperlinkBase = "https://www.autodesk.com"
ThisDrawing.SummaryInfo.Keywords = "Building Complex"
ThisDrawing.SummaryInfo.LastSavedBy = "JD"
ThisDrawing.SummaryInfo.RevisionNumber = "4"
ThisDrawing.SummaryInfo.Subject = "Plan for Building Five"
ThisDrawing.SummaryInfo.Title = "Building Five"
Author = ThisDrawing.SummaryInfo.Author
Comments = ThisDrawing.SummaryInfo.Comments
HLB = ThisDrawing.SummaryInfo.HyperlinkBase
KW = ThisDrawing.SummaryInfo.Keywords
LSB = ThisDrawing.SummaryInfo.LastSavedBy
RN = ThisDrawing.SummaryInfo.RevisionNumber
Subject = ThisDrawing.SummaryInfo.Subject
Title = ThisDrawing.SummaryInfo.Title
MsgBox "The standard drawing properties are " & vbCrLf & _
"Author = " & Author & vbCrLf & _
"Comments = " & Comments & vbCrLf & _
"HyperlinkBase = " & HLB & vbCrLf & _
"Keywords = " & KW & vbCrLf & _
"LastSavedBy = " & LSB & vbCrLf & _
"RevisionNumber = " & RN & vbCrLf & _
"Subject = " & Subject & vbCrLf & _
"Title = " & Title & vbCrLf
' Add and display custom properties
Dim Key0 As String
Dim Value0 As String
Dim Key1 As String
Dim Value1 As String
Dim CustomPropertyBranch As String
Dim PropertyBranchValue As String
Dim CustomPropertyZone As String
Dim PropertyZoneValue As String
CustomPropertyBranch = "Branch"
PropertyBranchValue = "Main"
CustomPropertyZone = "Zone"
PropertyZoneValue = "Industrial"
' Add custom properties
If (ThisDrawing.SummaryInfo.NumCustomInfo >= 1) Then
ThisDrawing.SummaryInfo.SetCustomByIndex 0, CustomPropertyBranch, PropertyBranchValue
Else
ThisDrawing.SummaryInfo.AddCustomInfo CustomPropertyBranch, PropertyBranchValue
End If
If (ThisDrawing.SummaryInfo.NumCustomInfo >= 2) Then
ThisDrawing.SummaryInfo.SetCustomByKey CustomPropertyBranch, "Satellite"
Else
ThisDrawing.SummaryInfo.AddCustomInfo CustomPropertyZone, PropertyZoneValue
End If
'Get custom properties
ThisDrawing.SummaryInfo.GetCustomByIndex 0, Key0, Value0
Key1 = CustomPropertyZone
ThisDrawing.SummaryInfo.GetCustomByKey Key1, Value1
MsgBox "The custom drawing properties are " & vbCrLf & _
"First property name = " & Key0 & vbCrLf & _
"First property value = " & Value0 & vbCrLf & _
"Second property name = " & Key1 & vbCrLf & _
"Second property value = " & Value1 & vbCrLf
Visual LISP: (vl-load-com)
(defun c:Example_NumCustomInfo()
;; This example shows how to access drawing properties
(setq summaryInfo (vla-get-SummaryInfo doc))
;; Add and display standard properties
(vla-put-Author summaryInfo "John Doe")
(vla-put-Comments summaryInfo "Includes all ten levels of Building Five")
(vla-put-HyperlinkBase summaryInfo "https://www.autodesk.com")
(vla-put-Keywords summaryInfo "Building Complex")
(vla-put-LastSavedBy summaryInfo "JD")
(vla-put-RevisionNumber summaryInfo "4")
(vla-put-Subject summaryInfo "Plan for Building Five")
(vla-put-Title summaryInfo "Building Five")
(setq author (vla-get-Author summaryInfo))
(setq comments (vla-get-Comments summaryInfo))
(setq HLB (vla-get-HyperlinkBase summaryInfo))
(setq KW (vla-get-Keywords summaryInfo))
(setq LSB (vla-get-LastSavedBy summaryInfo))
(setq RN (vla-get-RevisionNumber summaryInfo))
(setq subject (vla-get-Subject summaryInfo))
(setq Title (vla-get-Title summaryInfo))
(alert (strcat "The standard drawing properties are "
"\nAuthor = " author
"\nComments = " comments
"\nHyperlinkBase = " HLB
"\nKeywords = " KW
"\nLastSavedBy = " LSB
"\nRevisionNumber = " RN
"\nSubject = " Subject
"\nTitle = " Title
;; Add and display custom properties
(setq CustomPropertyBranch "Branch")
(setq PropertyBranchValue "Main")
(setq CustomPropertyZone "Zone")
(setq PropertyZoneValue "Industrial")
;; Add custom properties
(if (>= (vla-NumCustomInfo summaryInfo) 1)
(vla-SetCustomByIndex summaryInfo 0 CustomPropertyBranch PropertyBranchValue)
(vla-AddCustomInfo summaryInfo CustomPropertyBranch PropertyBranchValue)
(if (>= (vla-NumCustomInfo summaryInfo) 2)
(vla-SetCustomByKey summaryInfo CustomPropertyBranch "Satellite")
(vla-AddCustomInfo summaryInfo CustomPropertyZone PropertyZoneValue)
;; Get custom properties
(vla-GetCustomByIndex summaryInfo 0 'Key0 'Value0)
(setq Key1 CustomPropertyZone)
(vla-GetCustomByKey summaryInfo Key1 'Value1)
(alert (strcat "The custom drawing properties are "
"\nFirst property name = " Key0
"\nFirst property value = " Value0
"\nSecond property name = " Key1
"\nSecond property value = " Value1
GMT+8, 2026-11-2 19:05
