创建给定对象关于平面的镜像。 支持的平台:仅窗口 签名工 务 局: RetVal = object.Mirror3D(Point1, Point2, Point3) 言论![]() ![]() 围绕由三个点定义的平面镜像的对象 AutoCAD 检查要复制的对象是否拥有任何其他对象。如果是这样,它也会对这些对象执行复制。该过程将继续,直到复制了所有拥有的对象。 注意:不能在循环访问集合的同时执行此方法。迭代将为只读操作打开工作空间,而此方法将尝试执行读写操作。在调用此方法之前完成任何迭代。
属性引用:不应尝试对对象使用此方法。objects 继承此方法,因为它们是图形对象之一,但是,对属性参照执行此操作是不可行的。AttributeReferenceAttributeReference 例子工 务 局: Sub Example_Mirror3D()
' This example creates a box in model space, and mirrors the box about a plane.
Dim boxObj As Acad3DSolid
Dim length As Double, width As Double, height As Double
Dim center(0 To 2) As Double
' Define the box
center(0) = 5#: center(1) = 5#: center(2) = 0
length = 5#: width = 7: height = 10#
' Create the box (3DSolid) object in model space
Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
' Define the mirroring plane with three points
Dim mirrorPt1(0 To 2) As Double
Dim mirrorPt2(0 To 2) As Double
Dim mirrorPt3(0 To 2) As Double
mirrorPt1(0) = 1.25: mirrorPt1(1) = 0: mirrorPt1(2) = 0
mirrorPt2(0) = 1.25: mirrorPt2(1) = 2: mirrorPt2(2) = 0
mirrorPt3(0) = 1.25: mirrorPt3(1) = 2: mirrorPt3(2) = 2
' Mirror the box
Dim mirrorBoxObj As Acad3DSolid
Set mirrorBoxObj = boxObj.Mirror3D(mirrorPt1, mirrorPt2, mirrorPt3)
' Change the viewing direction of the viewport
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_Mirror3D()
;; This example creates a box in model space, and mirrors the box about a plane.
;; Define the box
(setq center (vlax-3d-point 5 5 0)
boxLength 5
boxWidth 7
boxHeight 10)
;; Create the box (3DSolid) object in model space
(setq boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
;; Define the mirroring plane with three points
(setq mirrorPt1 (vlax-3d-point 1.25 0 0)
mirrorPt2 (vlax-3d-point 1.25 2 0)
mirrorPt3 (vlax-3d-point 1.25 2 2))
;; Mirror the box
(setq mirrorBoxObj (vla-Mirror3D boxObj mirrorPt1 mirrorPt2 mirrorPt3))
;; Change the viewing direction of the viewport
(setq NewDirection (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
(vla-ZoomAll acadObj)
GMT+8, 2026-10-27 04:29
