插入已在当前图形中定义的图形文件或命名块。 支持的平台:仅窗口 签名工 务 局: RetVal = object.InsertBlock(InsertionPoint, Name [, Xscale [, Yscale [, ZScale [, Rotation [, Password]]]]])
言论将一个块插入另一个块将创建嵌套块。 尝试使用未初始化的Name参数调用该方法会导致意外行为。InsertBlock ExamplesVBA: Sub Example_InsertBlock()
' This example creates a block containing a circle.
' It then inserts the block.
' Create the block
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
' Add a circle to the block
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 0: center(1) = 0: center(2) = 0
radius = 1
Set circleObj = blockObj.AddCircle(center, radius)
' Insert the block
Dim blockRefObj As AcadBlockReference
insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_InsertBlock()
;; This example creates a block containing a circle.
;; It then inserts the block.
;; Create the block
(setq insertionPnt (vlax-3d-point 0 0 0))
(setq blockObj (vla-Add (vla-get-Blocks doc) insertionPnt "CircleBlock"))
;; Add a circle to the block
(setq center (vlax-3d-point 0 0 0)
radius 1)
(setq circleObj (vla-AddCircle blockObj center radius))
;; Insert the block
(setq insertionPnt (vlax-3d-point 2 2 0))
(setq blockRefObj (vla-InsertBlock modelSpace insertionPnt "CircleBlock" 1 1 1 0))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-26 21:46
