获取与对象关联的扩展数据 (XData)。 支持的平台:仅窗口 签名工 务 局: object.GetXData AppName, XDataType, XDataValue
返回值(RetVal)无返回值。 言论扩展数据是由使用 ObjectARX 或 AutoLISP 编写的应用程序创建的特定于实例的数据的一个示例。此数据可以添加到任何对象。此数据遵循对象的定义数据,并按保存到文档中的顺序进行维护。(AutoCAD 会保留此信息,但不使用它。 例子工 务 局: Sub Example_GetXData()
' This example creates a line and attaches extended data to that line.
' Create the line
Dim lineObj As AcadLine
Dim startPt(0 To 2) As Double, endPt(0 To 2) As Double
startPt(0) = 1#: startPt(1) = 1#: startPt(2) = 0#
endPt(0) = 5#: endPt(1) = 5#: endPt(2) = 0#
Set lineObj = ThisDrawing.ModelSpace.AddLine(startPt, endPt)
ZoomAll
' Initialize all the xdata values. Note that first data in the list should be
' application name and first datatype code should be 1001
Dim DataType(0 To 9) As Integer
Dim Data(0 To 9) As Variant
Dim reals3(0 To 2) As Double
Dim worldPos(0 To 2) As Double
DataType(0) = 1001: Data(0) = "Test_Application"
DataType(1) = 1000: Data(1) = "This is a test for xdata"
DataType(2) = 1003: Data(2) = "0" ' layer
DataType(3) = 1040: Data(3) = 1.23479137438413E+40 ' real
DataType(4) = 1041: Data(4) = 1237324938 ' distance
DataType(5) = 1070: Data(5) = 32767 ' 16 bit Integer
DataType(6) = 1071: Data(6) = 32767 ' 32 bit Integer
DataType(7) = 1042: Data(7) = 10 ' scaleFactor
reals3(0) = -2.95: reals3(1) = 100: reals3(2) = -20
DataType(8) = 1010: Data(8) = reals3 ' real
worldPos(0) = 4: worldPos(1) = 400.99999999: worldPos(2) = 2.798989
DataType(9) = 1011: Data(9) = worldPos ' world space position
' Attach the xdata to the line
lineObj.SetXData DataType, Data
' Return the xdata for the line
Dim xdataOut As Variant
Dim xtypeOut As Variant
lineObj.GetXData "", xtypeOut, xdataOut
Visual LISP: (vl-load-com)
(defun c:Example_GetXData()
;; This example creates a line and attaches extended data to that line.
;; Create the line
(setq startPt (vlax-3d-point 1 1 0)
endPt (vlax-3d-point 5 5 0))
(setq lineObj (vla-AddLine modelSpace startPt endPt))
(vla-ZoomAll acadObj)
;; Initialize all the xdata values. Note that first data in the list should be
;; application name and first datatype code should be 1001
(setq DataType (vlax-make-safearray vlax-vbInteger '(0 . 9)))
(setq Data (vlax-make-safearray vlax-vbVariant '(0 . 9)))
(vlax-safearray-put-element DataType 0 1001)
(vlax-safearray-put-element Data 0 "Test_Application")
(vlax-safearray-put-element DataType 1 1000)
(vlax-safearray-put-element Data 1 "This is a test for xdata")
;; layer
(vlax-safearray-put-element DataType 2 1003)
(vlax-safearray-put-element Data 2 "0")
;; real
(vlax-safearray-put-element DataType 3 1040)
(vlax-safearray-put-element Data 3 1.23479137438413E+40)
;; distance
(vlax-safearray-put-element DataType 4 1041)
(vlax-safearray-put-element Data 4 1237324938)
;; 16 bit Integer
(vlax-safearray-put-element DataType 5 1070)
(vlax-safearray-put-element Data 5 32767)
;; 32 bit Integer
(vlax-safearray-put-element DataType 6 1071)
(vlax-safearray-put-element Data 6 32767)
;; scaleFactor
(vlax-safearray-put-element DataType 7 1042)
(vlax-safearray-put-element Data 7 10)
;; 3D point
(setq reals3 (vlax-3d-point -2.95 100 -20))
(vlax-safearray-put-element DataType 8 1010)
(vlax-safearray-put-element Data 8 reals3)
;; world space position
(setq worldPos (vlax-3d-point 4 400.99999999 2.798989))
(vlax-safearray-put-element DataType 9 1011)
(vlax-safearray-put-element Data 9 worldPos)
;; Attach the xdata to the line
(vla-SetXData lineObj DataType Data)
;; Return the xdata for the line
(vla-GetXData lineObj "" 'xtypeOut 'xdataOut)
GMT+8, 2026-11-11 07:28
