获取由 UCS 坐标系数据组成的转换矩阵。 支持的平台:仅窗口 返回值(RetVal)类型:变体(4x4 双精度数组) UCS 矩阵。 言论若要将实体转换为给定的 UCS,请使用该方法,使用此方法返回的矩阵作为该方法的输入。TransformBy 例子工 务 局: Sub Example_GetUCSMatrix()
' This example creates a new UCS and finds the UCS matrix for it.
' It then creates a circle using WCS coordinates and
' transforms the circle for the UCS.
' Define a new UCS and turn on the UCS icon at the origin.
Dim ucsObj As AcadUCS
Dim origin(0 To 2) As Double
Dim xAxisPoint(0 To 2) As Double
Dim yAxisPoint(0 To 2) As Double
origin(0) = 2: origin(1) = 2: origin(2) = 0
xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) = 0
yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) = 0
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
ThisDrawing.ActiveUCS = ucsObj
ThisDrawing.ActiveViewport.UCSIconOn = True
ThisDrawing.ActiveViewport.UCSIconAtOrigin = True
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
' Create a circle using WCS coordinates
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 1: center(1) = 1: center(2) = 0
radius = 0.5
Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
ZoomAll
' Get the UCS transformation matrix
Dim TransMatrix As Variant
TransMatrix = ucsObj.GetUCSMatrix()
' Transform the circle to the UCS coordinates
MsgBox "Transform the circle.", , "GetUCSMatrix Example"
circleObj.TransformBy (TransMatrix)
circleObj.Update
MsgBox "The circle is transformed.", , "GetUCSMatrix Example"
Visual LISP: (vl-load-com)
(defun c:Example_GetUCSMatrix()
;; This example creates a new UCS and finds the UCS matrix for it.
;; It then creates a circle using WCS coordinates and
;; transforms the circle for the UCS.
;; Define a new UCS and turn on the UCS icon at the origin.
(setq origin (vlax-3d-point 2 2 0)
xAxisPoint (vlax-3d-point 3 2 0)
yAxisPoint (vlax-3d-point 2 3 0))
(setq ucsObj (vla-Add (vla-get-UserCoordinateSystems doc) origin xAxisPoint yAxisPoint "UCS1"))
(vla-put-ActiveUCS doc ucsObj)
(vla-put-UCSIconOn (vla-get-ActiveViewport doc) :vlax-true)
(vla-put-UCSIconAtOrigin (vla-get-ActiveViewport doc) :vlax-true)
(vla-put-ActiveViewport doc (vla-get-ActiveViewport doc))
;; Create a circle using WCS coordinates
(setq center (vlax-3d-point 1 1 0)
radius 0.5)
(setq circleObj (vla-AddCircle modelSpace center radius))
(vla-ZoomAll acadObj)
;; Get the UCS transformation matrix
(setq TransMatrix (vla-GetUCSMatrix ucsObj))
;; Transform the circle to the UCS coordinates
(alert "Transform the circle.")
(vla-TransformBy circleObj TransMatrix)
(vla-Update circleObj)
(alert "The circle is transformed.")
GMT+8, 2026-10-28 11:10
