获取指定的角度。忽略 ANGBASE 系统变量的设置。 支持的平台:仅窗口 签名工 务 局: RetVal = object.GetOrientation([Point [, Prompt]])
返回值(RetVal)类型:双 指定的角度。 言论AutoCAD 为用户输入的角度而暂停,并将返回值设置为所选角度的值。点参数指定 WCS 中的角度基点。提示参数指定 AutoCAD 在暂停之前显示的字符串。“点”和“提示”都是可选的。 AutoCAD 用户可以通过输入当前角度单位格式的数字来指定角度。用户还可以通过在图形屏幕上指定两个 2D 位置来指定角度。AutoCAD 绘制一条从第一个点到当前十字准线位置的橡皮筋线,以帮助用户可视化角度。如果提供了“点”参数,AutoCAD 将使用此值作为两个点中的第一个。角度在 WCS 的XY平面中测量(此方法忽略点的Z字段)。角增加的方向总是逆时针方向。 无论使用哪种方法指定角度,始终将返回值设置为以弧度表示的值。GetOrientation 此方法类似于该方法,但它忽略了存储在 ANGBASE 系统变量中的角度 0 的当前方向。使用的 0 角度始终在右侧:“东”或“三点钟”。GetAngleGetOrientation 如果返回的是关键字而不是角度,AutoCAD 将生成错误消息“用户输入关键字”。使用该方法从返回值中获取关键字。GetInput 例子工 务 局: Sub Example_GetOrientation()
' This example uses the GetOrientation method to demonstrate three different ways to retrieve
' an orientation from the user.
Dim retOrientation As Double
' Return the Orientation in radians with a prompt
retOrientation = ThisDrawing.Utility.GetOrientation(, "Enter an Orientation: ")
MsgBox "The Orientation entered was " & retOrientation & vbCrLf & _
"(Enter the next value without prompting.)", , "GetOrientation Example"
' Return the Orientation in radians without any prompt
retOrientation = ThisDrawing.Utility.GetOrientation()
MsgBox "The Orientation entered was " & retOrientation, , "GetOrientation Example"
' Return the Orientation in radians with a prompt and an Orientation base point
Dim basePnt(0 To 2) As Double
basePnt(0) = 2#: basePnt(1) = 2#: basePnt(2) = 0#
retOrientation = ThisDrawing.Utility.GetOrientation(basePnt, "Enter an Orientation: ")
Visual LISP: (vl-load-com)
(defun c:Example_GetOrientation()
;; This example uses the GetOrientation method to demonstrate three different ways to retrieve
;; an orientation from the user.
;; Return the Orientation in radians with a prompt
(setq retOrientation (vla-GetOrientation (vla-get-Utility doc) nil "Enter an Orientation: "))
(alert (strcat "The Orientation entered was " (rtos retOrientation 2) "\n"
"(Enter the next value without prompting.)"))
;; Return the Orientation in radians without any prompt
(setq retOrientation (vla-GetOrientation (vla-get-Utility doc)))
(alert (strcat "The Orientation entered was " (rtos retOrientation 2)))
;; Return the Orientation in radians with a prompt and an Orientation base point
(setq basePnt (vlax-3d-point 2 2 0))
(setq retOrientation (vla-GetOrientation (vla-get-Utility doc) basePnt "Enter an Orientation: "))
GMT+8, 2026-11-2 03:37
