从用户获取整数值。 支持的平台:仅窗口 签名工 务 局: RetVal = object.GetInteger([Prompt])
返回值(RetVal)类型:长 用户返回的整数值。 言论AutoCAD 会暂停用户输入整数,并将返回值设置为所选值。提示参数指定 AutoCAD 在暂停之前显示的字符串。提示是可选的。 AutoCAD 用户可以输入 -32,768 到 +32,767 范围内的任何有效(短)整数。 如果返回的是关键字而不是整数,或者如果用户按 Enter 键而不输入值,AutoCAD 将生成错误号 -2145320928(以及错误消息“用户输入是关键字”)。使用该方法从返回值中获取关键字。GetInput 例子工 务 局: Sub Example_GetInteger()
' This example returns the integer entered by the user.
Dim returnInt As Integer
' Return the value entered by user. A prompt is provided.
returnInt = ThisDrawing.Utility.GetInteger("Enter an integer: ")
MsgBox "The integer entered was " & returnInt & vbCrLf & _
"(Enter the next value without prompting.)", , "GetInteger Example"
' Return the value entered by user. No prompt is provided.
returnInt = ThisDrawing.Utility.GetInteger()
MsgBox "The integer entered was " & returnInt, , "GetInteger Example"
Visual LISP: (vl-load-com)
(defun c:Example_GetInteger()
;; This example returns the integer entered by the user.
;; Return the value entered by user. A prompt is provided.
(setq returnInt (vla-GetInteger (vla-get-Utility doc) "Enter an integer: "))
(alert (strcat "The integer entered was " (itoa returnInt)
"\n(Enter the next value without prompting.)"))
;; Return the value entered by user. No prompt is provided.
(setq returnInt (vla-GetInteger (vla-get-Utility doc)))
(alert (strcat "The integer entered was " (itoa returnInt)))
GMT+8, 2026-10-31 21:23
