获取与对象关联的扩展字典。 支持的平台:仅窗口 签名工 务 局: RetVal = object.GetExtensionDictionary 言论如果对象没有扩展字典,则此方法将为该对象创建新的扩展字典,并在返回值中返回它。 可以使用属性查询对象以查看它是否具有扩展字典。HasExtensionDictionary 例子工 务 局: Sub Example_GetExtensionDictionary()
' This example creates a Circle object in model space and
' adds a new Extension Dictionary to the Circle object
Dim EDictionary As AcadDictionary
Dim circleObj As AcadCircle
Dim radius As Double
' Define the Circle object
centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
radius = 5#
' Create the Circle object in model space
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
MsgBox "Circle object Extension Dictionary state before: " & circleObj.HasExtensionDictionary
' Create an Extension Dictionary for the new Circle
Set EDictionary = circleObj.GetExtensionDictionary
MsgBox "Circle object Extension Dictionary state after: " & circleObj.HasExtensionDictionary
Visual LISP: (vl-load-com)
(defun c:Example_GetExtensionDictionary()
;; This example creates a Circle object in model space and
;; adds a new Extension Dictionary to the Circle object
;; Define the Circle object
(setq centerPoint (vlax-3d-point 0 0 0)
radius 5)
;; Create the Circle object in model space
(setq circleObj (vla-AddCircle modelSpace centerPoint radius))
(vla-ZoomAll acadObj)
(alert (strcat "Circle object Extension Dictionary state before: " (if (= (vla-get-HasExtensionDictionary circleObj) :vlax-true) "True" "False")))
;; Create an Extension Dictionary for the new Circle
(setq EDictionary (vla-GetExtensionDictionary circleObj))
(alert (strcat "Circle object Extension Dictionary state after: " (if (= (vla-get-HasExtensionDictionary circleObj) :vlax-true) "True" "False")))
GMT+8, 2026-10-28 18:24
