获取块或外部引用中的常量属性。 支持的平台:仅窗口 言论此方法返回附加到块或外部引用的常量属性数组。返回的属性是常量属性定义,而不是属性引用。 例子工 务 局: Sub Example_GetConstantAttributes()
' This example creates a constant attribute definition on a block.
' It then queries the block to return the attribute.
' Create the block to hold the attribute
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "New_Block")
' Define the attribute definition
Dim attributeObj As AcadAttribute
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
height = 1#
mode = acAttributeModeConstant
prompt = "Constant Prompt"
insertionPnt(0) = 5#: insertionPnt(1) = 5#: insertionPnt(2) = 0#
tag = "Constant_Tag"
value = "Constant Value"
' Create the attribute definition object on the block
Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPnt, tag, value)
ZoomAll
' Insert the block into the drawing
Dim blockRefObj As AcadBlockReference
insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "New_Block", 1#, 1#, 1#, 0)
' Get the constant attribute definition from the block
Dim queryAttribute As Variant
queryAttribute = blockRefObj.GetConstantAttributes
Dim count As Integer
count = UBound(queryAttribute) - LBound(queryAttribute)
MsgBox "The block reference has " & count & " constant attributes."
Visual LISP: (vl-load-com)
(defun c:Example_GetConstantAttributes()
;; This example creates a constant attribute definition on a block.
;; It then queries the block to return the attribute.
;; Create the block to hold the attribute
(setq insertionPnt (vlax-3d-point 0 0 0))
(setq blockObj (vla-Add (vla-get-Blocks doc) insertionPnt "New_Block"))
;; Define the attribute definition
(setq insertionPnt (vlax-3d-point 5 5 0)
attHeight 1
attMode acAttributeModeConstant
attPrompt "Constant Prompt"
attTag "Constant_Tag"
attValue "Constant Value")
;; Create the attribute definition object on the block
(setq attributeObj (vla-AddAttribute blockObj attHeight attMode attPrompt insertionPnt attTag attValue))
;; Insert the block into the drawing
(setq insertionPnt (vlax-3d-point 2 2 0))
(setq blockRefObj (vla-InsertBlock modelSpace insertionPnt "New_Block" 1 1 1 0))
(vla-ZoomAll acadObj)
;; Get the constant attribute definition from the block
(setq queryAttribute (vlax-variant-value (vla-GetConstantAttributes blockRefObj)))
(setq count (1+ (vlax-safearray-get-u-bound queryAttribute 1)))
(alert (strcat "The block reference has " (itoa count) " constant attributes."))
GMT+8, 2026-10-28 16:08
