ActiveX 开发指南
相关分类
GetBackgroundColor Method (ActiveX)
2023-1-4 10:00| 发布者: admin| 查看: 1853| 评论: 0|来自: AutoCAD
摘要: 返回指定行类型的背景色值。
返回指定行类型的背景色值。
支持的平台:仅窗口
工 务 局:
RetVal = object.GetBackgroundColor(rowType)
类型:表格,表格样式
此方法适用的对象。
行类型
访问:仅输入
类型:枚举AcRowType
行类型。
  • acDataRow
  • acHeaderRow
  • acTitleRow
  • acUnknownRow
返回值(RetVal)
类型:AcCm颜色
指定给行类型的背景色的 AutoCAD 真彩色对象。
没有额外的评论。
工 务 局:
Sub Example_GetBackgroundColor()
    ' the style name and other attributes.
    Dim dictObj As AcadDictionary
    ' Get the current TableStyle object
    Dim tableStyle As AcadTableStyle
    Set tableStyle = dictObj.Item(ThisDrawing.GetVariable("CTABLESTYLE"))
    Dim colCurrent As AcadAcCmColor, colRowCurrent As AcadAcCmColor, colNoneCurrent As Boolean
    Set colCurrent = tableStyle.GetBackgroundColor(AcRowType.acDataRow + AcRowType.acTitleRow)
    Set colRowCurrent = tableStyle.GetColor(acDataRow)
    colNoneCurrent = tableStyle.GetBackgroundColorNone(AcRowType.acHeaderRow)
    MsgBox "Table colors " & vbLf & _
           "Background ACI value = " & colCurrent.ColorIndex & vbLf & _
           "Row Text ACI value = " & colRowCurrent.ColorIndex & vbLf & _
           "Background None = " & colNoneCurrent
    Dim col As AcadAcCmColor
    Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
    col.SetRGB 0, 0, 255
    tableStyle.SetBackgroundColor AcRowType.acTitleRow, col
    col.SetRGB 255, 0, 0
    tableStyle.SetColor AcRowType.acDataRow, col
    If colNoneCurrent = False Then
        tableStyle.SetBackgroundColorNone AcRowType.acHeaderRow, True
    Else
        tableStyle.SetBackgroundColorNone AcRowType.acHeaderRow, False
    End If
    Dim colNew As AcadAcCmColor, colRowNew As AcadAcCmColor, colNoneNew As Boolean
    Set colNew = tableStyle.GetBackgroundColor(AcRowType.acTitleRow)
    Set colRowNew = tableStyle.GetColor(acDataRow)
    colNoneNew = tableStyle.GetBackgroundColorNone(acHeaderRow)
           "Background ACI value = " & colNew.ColorIndex & vbLf & _
           "Row Text ACI value = " & colRowNew.ColorIndex & vbLf & _
           "Background None = " & colNoneNew
    tableStyle.SetBackgroundColor AcRowType.acTitleRow, colCurrent
    tableStyle.SetColor AcRowType.acDataRow, colRowCurrent
    tableStyle.SetBackgroundColorNone AcRowType.acHeaderRow, colNoneCurrent
    MsgBox "Reset the table style back to its original values."
Visual LISP:
(defun c:Example_GetBackgroundColor()
    ;; the style name and other attributes.
    (setq dictObj (vla-Item dictionaries "acad_tablestyle"))
    ;; Get the current TableStyle object
    (setq tableStyle (vla-Item dictObj (vla-GetVariable doc "CTABLESTYLE")))
    (setq colCurrent (vla-GetBackgroundColor tableStyle (+ acDataRow acTitleRow)))
    (setq colRowCurrent (vla-GetColor tableStyle acDataRow))
    (setq colNoneCurrent (vla-GetBackgroundColorNone tableStyle acHeaderRow))
    (alert (strcat "Table colors \n"
		                 "Background ACI value = " (itoa (vla-get-ColorIndex colCurrent)) "\n"
		                 "Row Text ACI value = " (itoa (vla-get-ColorIndex colRowCurrent)) "\n"
		                 "Background None = " (if (= colNoneCurrent :vlax-true) "True" "False")))
    (setq col (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-SetRGB col 0 0 255)
    (vla-SetBackgroundColor tableStyle acTitleRow col)
    (vla-SetRGB col 255 0 0)
    (vla-SetColor tableStyle acDataRow col)
    (vla-SetBackgroundColorNone tableStyle acHeaderRow (if (= colNoneCurrent :vlax-true) :vlax-false :vlax-true))
    (setq colNew (vla-GetBackgroundColor tableStyle acTitleRow))
    (setq colRowNew (vla-GetColor tableStyle acDataRow))
    (setq colNoneNew (vla-GetBackgroundColorNone tableStyle acHeaderRow))
		                 "Background ACI value = " (itoa (vla-get-ColorIndex colNew)) "\n"
		                 "Row Text ACI value = " (itoa (vla-get-ColorIndex colRowNew)) "\n"
		                 "Background None = " (if (= colNoneNew :vlax-true) "True" "False")))
    (vla-SetBackgroundColor tableStyle acTitleRow colCurrent)
    (vla-SetColor tableStyle acDataRow colRowCurrent)
    (vla-SetBackgroundColorNone tableStyle acHeaderRow colNoneCurrent)
    (alert "Reset the table style back to its original values.")
    (vlax-release-object col)
GMT+8, 2026-10-25 19:56
