导出活动配置文件,以便与其他用户共享。 支持的平台:仅窗口 签名工 务 局: object.ExportProfile Profile, RegFile
返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_ExportProfile()
' This example exports the active profile to a new name.
Dim currActiveProfile As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current ActiveProfile value
currActiveProfile = preferences.Profiles.ActiveProfile
MsgBox "The current ActiveProfile is: " & preferences.Profiles.ActiveProfile, , "ExportProfile Example"
' Export the active profile
preferences.Profiles.ExportProfile currActiveProfile, "TestProfile.arg"
MsgBox "The ActiveProfile has been exported to: TestProfile.arg", , "ExportProfile Example"
Visual LISP: (vl-load-com)
(defun c:Example_ExportProfile()
;; This example exports the active profile to a new name.
;; Retrieve the current ActiveProfile value
(setq currActiveProfile (vla-get-ActiveProfile (vla-get-Profiles preferences)))
(alert (strcat "The current ActiveProfile is: " currActiveProfile))
;; Export the active profile
(vla-ExportProfile (vla-get-Profiles preferences) currActiveProfile "c:\\Temp\\TestProfile.arg")
(alert "The ActiveProfile has been exported to: TestProfile.arg")
GMT+8, 2026-10-28 13:17
