控制单元格合并。 支持的平台:仅窗口 签名工 务 局: object.EnableMergeAll nRow, nCol, bEnable
返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_EnableMergeAll()
' the style cell merging.
Dim dictObj As AcadDictionary
' Create the custom TableStyle object in the dictionary
Dim keyName As String
Dim className As String
Dim customObj As IAcadTableStyle
keyName = "NewStyle"
className = "AcDbTableStyle"
Set customObj = dictObj.AddObject(keyName, className)
customObj.Name = "NewStyle"
customObj.Description = "New Style for My Tables"
customObj.CreateCellStyle "NewTestStyle2"
customObj.EnableMergeAll "NewTestStyle2", False
If customObj.GetIsMergeAllEnabled("NewTestStyle2") = False Then
MsgBox "Merge all is not enabled!"
End If
Visual LISP: (vl-load-com)
(defun c:Example_EnableMergeAll()
;; the style cell merging.
(setq dictObj (vla-Item dictionaries "acad_tablestyle"))
;; Create the custom TableStyle object in the dictionary
(setq keyName "NewStyle"
className "AcDbTableStyle")
(setq customObj (vla-AddObject dictObj keyName className))
(vla-put-Name customObj "NewStyle")
(vla-put-Description customObj "New Style for My Tables")
(vla-CreateCellStyle customObj "NewTestStyle2")
(vla-EnableMergeAll customObj "NewTestStyle2" :vlax-false)
(if (= (vla-GetIsMergeAllEnabled customObj "NewTestStyle2") :vlax-false)
(alert "Merge all is not enabled!")
GMT+8, 2026-10-28 10:27
