ActiveX 开发指南
相关分类
停靠方法 (ActiveX)
2023-1-4 10:42| 发布者: admin| 查看: 1865| 评论: 0|来自: AutoCAD
摘要: 将工具栏停靠到所属框架窗口。
将工具栏停靠到所属框架窗口。
支持的平台:仅窗口
工 务 局:
object.Dock Side
类型:工具栏
此方法适用的对象。
边
访问:仅输入
类型:枚举AcToolbarDockStatus
要停靠的工具栏一侧。
  • acToolbarDockTop
  • acToolbarDockBottom
  • acToolbarDockLeft
  • acToolbarDockRight
返回值(RetVal)
无返回值。
没有额外的评论。
工 务 局:
Sub Example_Dock()
    ' This example creates a new toolbar called TestToolbar and inserts three
    ' buttons into it. The toolbar is then displayed as a floating toolbar,
    ' and then as a docked toolbar.
    ' To remove the toolbar after execution of this macro, use the Customize Menu
    ' option from the Tools menu.
    Dim currMenuGroup As acadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    ' Create the new toolbar
    Dim newToolBar As AcadToolbar
    Set newToolBar = currMenuGroup.Toolbars.Add("TestToolbar")
    ' Add three buttons to the new toolbar.
    ' All three buttons will have the same macro attached.
    Dim newButton1 As AcadToolbarItem
    Dim newButton2 As AcadToolbarItem
    Dim newButton3 As AcadToolbarItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set newButton1 = newToolBar.AddToolbarButton("", "NewButton1", "Open a file.", openMacro)
    Set newButton2 = newToolBar.AddToolbarButton("", "NewButton2", "Open a file.", openMacro)
    Set newButton3 = newToolBar.AddToolbarButton("", "NewButton3", "Open a file.", openMacro)
    ' Display the toolbar
    newToolBar.Visible = True
    ' Dock the toolbar to the left of the screen.
    newToolBar.Dock acToolbarDockLeft
    MsgBox "The toolbar is docked to the left."
    ' Dock the toolbar to the right of the screen.
    newToolBar.Dock acToolbarDockRight
    MsgBox "The toolbar is docked to the right."
    ' Dock the toolbar at the top of the screen.
    newToolBar.Dock acToolbarDockTop
    MsgBox "The toolbar is docked at the top."
    ' Dock the toolbar at the bottom of the screen.
    newToolBar.Dock acToolbarDockBottom
    MsgBox "The toolbar is docked at the bottom."
Visual LISP:
(defun c:Example_Dock()
    ;; This example creates a new toolbar called TestToolbar and inserts three
    ;; buttons into it. The toolbar is then displayed as a floating toolbar,
    ;; and then as a docked toolbar.
    ;; To remove the toolbar after execution of this macro, use the Customize Menu
    ;; option from the Tools menu.
    (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
    ;; Create the new toolbar
    (setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "TestToolbar"))
    ;; Add three buttons to the new toolbar.
    ;; All three buttons will have the same macro attached.
    ;; Assign the macro string the VB equivalent of "ESC ESC _open "
    (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
    (setq newButton1 (vla-AddToolbarButton newToolBar "" "NewButton1" "Open a file." openMacro))
    (setq newButton2 (vla-AddToolbarButton newToolBar "" "NewButton2" "Open a file." openMacro))
    (setq newButton3 (vla-AddToolbarButton newToolBar "" "NewButton3" "Open a file." openMacro))
    ;; Display the toolbar
    (vla-put-Visible newToolBar :vlax-true)
    ;; Dock the toolbar to the left of the screen.
    (vla-Dock newToolBar acToolbarDockLeft)
    (alert "The toolbar is docked to the left.")
    ;; Dock the toolbar to the right of the screen.
    (vla-Dock newToolBar acToolbarDockRight)
    (alert "The toolbar is docked to the right.")
    ;; Dock the toolbar at the top of the screen.
    (vla-Dock newToolBar acToolbarDockTop)
    (alert "The toolbar is docked at the top.")
    ;; Dock the toolbar at the bottom of the screen.
    (vla-Dock newToolBar acToolbarDockBottom)
    (alert "The toolbar is docked at the bottom.")
GMT+8, 2026-10-26 22:41
