ActiveX 开发指南
相关分类
分离方法 (ActiveX)
2023-1-4 10:50| 发布者: admin| 查看: 1810| 评论: 0|来自: AutoCAD
摘要: 从图形分离外部参照 (xref)。
从图形分离外部参照 (xref)。
支持的平台:仅窗口
工 务 局:
object.Detach
类型:块
此方法适用的对象。
返回值(RetVal)
无返回值。
分离外部参照将从当前图形中删除外部参照。外部参照的所有副本都将拭除,外部参照定义将被删除。所有与外部参照相关的符号表信息(例如图层和线型)都将从当前图形中删除。
不能分离包含其他外部参照的外部参照。
工 务 局:
Sub Example_Detach()
    On Error GoTo ERRORHANDLER
    ' Define external reference to be inserted
    Dim xrefHome As AcadBlock
    Dim xrefInserted As AcadExternalReference
    Dim insertionPnt(0 To 2) As Double
    Dim PathName As String
    insertionPnt(0) = 1
    insertionPnt(1) = 1
    insertionPnt(2) = 0
    PathName = "c:/AutoCAD/sample/City map.dwg"
    ' Add the external reference
    Set xrefInserted = ThisDrawing.ModelSpace. _
            AttachExternalReference(PathName, "XREF_IMAGE", _
            insertionPnt, 1, 1, 1, 0, False)
    ZoomAll
    MsgBox "The external reference is attached."
    ' Detach the external reference definition
    Dim name As String
    name = xrefInserted.name
    ThisDrawing.Blocks.Item(name).Detach
    MsgBox "The external reference is detached."
    Exit Sub
ERRORHANDLER:
    MsgBox Err.Description
Visual LISP:
(defun c:Example_Detach()
    ;; Define external reference to be inserted
    (setq insertionPnt (vlax-3d-point 1 1 0)
          pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
    ;; Add the external reference
    (setq xrefInserted (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" insertionPnt 1 1 1 0 :vlax-false))
    (vla-ZoomAll acadObj)
    (alert "The external reference is attached.")
    ;; Detach the external reference definition
    (setq name (vla-get-Name xrefInserted))
    (vla-Detach (vla-Item (vla-get-Blocks doc) name))
    (alert "The external reference is detached.")
GMT+8, 2026-10-25 05:08
