ActiveX 开发指南
相关分类
删除配置方法 (ActiveX)
2023-1-4 10:57| 发布者: admin| 查看: 1864| 评论: 0|来自: AutoCAD
摘要: 删除视口配置。
删除视口配置。
支持的平台:仅窗口
工 务 局:
object.DeleteConfiguration Name
类型:视口
此方法适用的对象。
名字
访问:仅输入
类型:字符串
要删除的视区配置的名称。
返回值(RetVal)
无返回值。
视口配置由使用该方法拆分的单个视口组成。拆分视口后,生成的视口将被视为视口配置。配置中的所有视口与拆分前的原始视口同名。Split
工 务 局:
Sub Example_DeleteConfiguration()
    ' This example creates a new viewport and splits
    ' the viewport into 4 windows.
    ' It then deletes the viewport configuration
    Dim oldViewport As AcadViewport
    Set oldViewport = ThisDrawing.ActiveViewport
    ' Create a new viewport and make it active
    Dim newViewport As AcadViewport
    Set newViewport = ThisDrawing.Viewports.Add("TESTVIEWPORT")
    ThisDrawing.ActiveViewport = newViewport
    ' Split the viewport in 4 windows
    newViewport.Split acViewport4
    ' Make the newly split viewport active
    MsgBox "The viewport configuration split into 4 windows."
    ' Delete the viewport configuration
    ThisDrawing.ActiveViewport = oldViewport
    ThisDrawing.Viewports.DeleteConfiguration ("TESTVIEWPORT")
    MsgBox "The viewport configuration has been deleted."
Visual LISP:
(defun c:Example_DeleteConfiguration()
    ;; This example creates a new viewport and splits
    ;; the viewport into 4 windows.
    ;; It then deletes the viewport configuration
    (setq oldViewport (vla-Add (vla-get-Viewports doc) "CurrentViewport"))
    ;; Create a new viewport and make it active
    (setq newViewport (vla-Add (vla-get-Viewports doc) "NewViewport"))
    (vla-put-ActiveViewport doc newViewport)
    ;; Split the viewport in 4 windows
    (vla-Split newViewport acViewport4)
    ;; Make the newly split viewport active
    (alert "The viewport configuration split into 4 windows.")
    ;; Delete the viewport configuration
    (vla-put-ActiveViewport doc oldViewport)
    (vla-DeleteConfiguration (vla-get-Viewports doc) "NewViewport")
    (vla-DeleteConfiguration (vla-get-Viewports doc) "CurrentViewport")
    (alert "The viewport configurations have been deleted and original viewport restored.")
GMT+8, 2026-10-25 23:02
