向图形中添加表格。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddTable(InsertionPoint, NumRows, NumColumns, RowHeight, ColWidth) 言论没有额外的评论。 例子工 务 局: Sub Example_AddTable()
' This example adds a table in model space
Dim MyModelSpace As AcadModelSpace
Set MyModelSpace = ThisDrawing.ModelSpace
Dim pt(2) As Double
Dim MyTable As AcadTable
Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 10, 30)
ZoomExtents
Visual LISP: (vl-load-com)
(defun c:Example_AddTable()
;; This example adds a table in model space
(setq pt (vlax-3d-point 0 0 0))
(setq MyTable (vla-Addtable modelSpace pt 5 5 10 30))
(vla-ZoomExtents acadObj)
GMT+8, 2026-11-12 08:21
