从一组实体创建一个区域。给定的图元必须形成一个封闭的共面区域。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddRegion(ObjectList) 言论此方法将从曲线输入数组形成的每个闭环中创建一个区域。AutoCAD 将闭合的二维和平面三维多段线转换为单独的区域,然后转换形成闭合平面环的多段线、直线和曲线。如果两条以上的曲线共享一个端点,则生成的区域可能是任意的。 您可以使用该方法将区域分解为各个循环。该方法允许您从实体或区域与另一个实体或区域的交点、并集或减法来创建复合 3D 实体或区域。ExplodeBoolean 创建的对象总数为 。RegionUbound(objRegions) - Lbound(objRegions) + 1 例子工 务 局: Sub Example_AddRegion()
' This example creates a region from an arc and a line.
Dim curves(0 To 1) As AcadEntity
' Define the arc
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
radius = 2#
startAngle = 0
endAngle = 3.141592
Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
' Define the line
Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).startPoint, curves(0).endPoint)
' Create the region
Dim regionObj As Variant
regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_AddRegion()
;; This example creates a region from an arc and a line.
;; Define the arc
(setq centerPoint (vlax-3d-point 5 3 0)
radius 2
startAngle 0
endAngle 3.141592)
(setq arc (vla-AddArc modelSpace centerPoint radius startAngle endAngle))
;; Define the line
(setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc)))
(setq curves (vlax-make-safearray vlax-vbObject '(0 . 1)))
(vlax-safearray-put-element curves 0 arc)
(vlax-safearray-put-element curves 1 line)
;; Create the region
(setq regionObj (vla-AddRegion modelSpace curves))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-25 19:55
