在给定位置创建 Point 对象。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddPoint(Point) 言论没有额外的评论。 例子工 务 局: Sub Example_AddPoint()
' This example creates a point in model space.
Dim pointObj As AcadPoint
' Define the location of the point
location(0) = 5#: location(1) = 5#: location(2) = 0#
' Create the point
Set pointObj = ThisDrawing.ModelSpace.AddPoint(location)
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_AddPoint()
;; This example creates a point in model space.
;; Define the location of the point
(setq location (vlax-3d-point 5 5 0))
;; Create the point
(setq pointObj (vla-AddPoint modelSpace location))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-29 01:52
