在由边界框的插入点和宽度定义的矩形中创建 MText 实体。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddMText(InsertionPoint, Width, Text) 言论没有额外的评论。 例子工 务 局: Sub Example_AddMtext()
' This example creates an MText object in model space.
Dim MTextObj As AcadMText
Dim corner(0 To 2) As Double
Dim width As Double
Dim text As String
corner(0) = 0#: corner(1) = 10#: corner(2) = 0#
width = 10
text = "This is the text String for the mtext Object"
' Creates the mtext Object
Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_AddMtext()
;; This example creates an MText object in model space.
;; Define the multiline text object
(setq corner (vlax-3d-point 0 10 0)
width 10
text "This is the text String for the mtext Object")
;; Creates the mtext Object
(setq MTextObj (vla-AddMText modelSpace corner width text))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-27 21:15
