将弹出菜单项添加到弹出菜单。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddMenuItem(Index, Label, Macro)
言论没有额外的评论。 例子工 务 局: Sub Example_AddMenuItem()
' This example creates a new menu called TestMenu and inserts a menu item
' into it. The menu is then displayed on the menu bar.
' To remove the menu after execution of this macro, use the Customize Menu
' option from the Tools menu.
Dim currMenuGroup As acadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
' Create the new menu
Dim newMenu As AcadPopupMenu
Set newMenu = currMenuGroup.Menus.Add("TestMenu")
' Add a menu item to the new menu
Dim newMenuItem As AcadPopupMenuItem
Dim openMacro As String
' Assign the macro string the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro)
' Display the menu on the menu bar
newMenu.InsertInMenuBar ThisDrawing.Application.MenuBar.count + 1
Visual LISP: (vl-load-com)
(defun c:Example_AddMenuItem()
;; This example creates a new menu called TestMenu and inserts a menu item
;; into it. The menu is then displayed on the menu bar.
;; To remove the menu after execution of this macro, use the Customize Menu
;; option from the Tools menu.
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create the new menu
(setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
;; Add a menu item to the new menu
;; Assign the macro string the VB equivalent of "ESC ESC _open "
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newMenuItem (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "Open" openMacro))
;; Display the menu on the menu bar
(vla-InsertInMenuBar newMenu (1+ (vla-get-Count (vla-get-MenuBar acadObj))))
;; Display the menu bar
(vla-SetVariable doc "MENUBAR" 1)
GMT+8, 2026-10-28 13:18
