创建一条穿过两点的线。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddLine(StartPoint, EndPoint) 言论没有额外的评论。 例子工 务 局: Sub Example_AddLine()
' This example adds a line in model space
Dim lineObj As AcadLine
' Define the start and end points for the line
startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
' Create the line in model space
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_AddLine()
;; This example adds a line in model space
;; Define the start and end points for the line
(setq startPoint (vlax-3d-point 1 1 0)
endPoint (vlax-3d-point 5 5 0))
;; Create the line in model space
(vla-ZoomAll acadObj)
GMT+8, 2026-9-13 03:55
