从顶点列表创建轻量级折线。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddLightWeightPolyline(VerticesList) 言论顶点指定构成折线的线段的端点。要添加弧段,请先创建包含所有线段的折线,然后向要成为弧的各个线段添加凸起。若要向段添加凸起值,请使用该方法。SetBulge 折线的高程将设置为布局的当前高程。使用理论属性确定折线的高程。ElevationModelspaceElevationPaperspace 可以使用该方法将坐标与OCS相互转换。TranslateCoordinates 例子工 务 局: Sub Example_AddLightWeightPolyline()
' This example creates a lightweight polyline in model space.
Dim points(0 To 9) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1
points(2) = 1: points(3) = 2
points(4) = 2: points(5) = 2
points(6) = 3: points(7) = 2
points(8) = 4: points(9) = 4
' Create a lightweight Polyline object in model space
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_AddLightWeightPolyline()
;; This example creates a lightweight polyline in model space.
;; Define the 2D polyline points
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 9)))
(vlax-safearray-fill points '(1 1
1 2
2 2
3 2
4 4
;; Create a lightweight Polyline object in model space
(setq plineObj (vla-AddLightWeightPolyline modelSpace points))
(vla-ZoomAll acadObj)
GMT+8, 2026-11-10 18:09
