将一个或多个对象添加到指定的选择集。 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论当前在指定选择集中的对象将保留在选择集中。要替换选择集中的对象,请使用该方法清除选择集,然后添加对象。Clear 要从选择集中移除单个对象,请使用该方法。RemoveItems 例子工 务 局: Sub Example_AddItems()
' This example creates a selection set and several objects.
' It then adds the objects to the selection set.
' Create the new selection set
Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SELECTIONSET")
' Create a Ray object in model space
Dim rayObj As AcadRay
Dim basePoint(0 To 2) As Double
Dim SecondPoint(0 To 2) As Double
basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint)
' Create a polyline object in model space
Dim points(0 To 5) As Double
points(0) = 3: points(1) = 7
points(2) = 9: points(3) = 2
points(4) = 3: points(5) = 5
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
plineObj.Closed = True
' Create a line object in model space
Dim lineObj As AcadLine
startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0
' Create a circle object in model space
Dim circObj As AcadCircle
Dim centerPt(0 To 2) As Double
Dim radius As Double
centerPt(0) = 20: centerPt(1) = 30: centerPt(2) = 0
radius = 3
Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
' Create an ellipse object in model space
Dim ellObj As AcadEllipse
Dim majAxis(0 To 2) As Double
Dim center(0 To 2) As Double
Dim radRatio As Double
center(0) = 5#: center(1) = 5#: center(2) = 0#
majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
radRatio = 0.3
Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
ZoomAll
' Iterate through the model space collection.
' Collect the objects found into an array of objects
' to be added to the selection set.
ReDim ssobjs(0 To ThisDrawing.ModelSpace.count - 1) As AcadEntity
Dim I As Integer
For I = 0 To ThisDrawing.ModelSpace.count - 1
Set ssobjs(I) = ThisDrawing.ModelSpace.Item(I)
Next
' Add the array of objects to the selection set
ssetObj.AddItems ssobjs
ThisDrawing.Regen acActiveViewport
Visual LISP: (vl-load-com)
(defun c:Example_AddItems()
;; This example creates a selection set and several objects.
;; It then adds the objects to the selection set.
;; Create the new selection set
(setq ssets (vla-get-SelectionSets doc))
(setq ssetObj (vla-Add ssets "TEST_SELECTIONSET"))
;; Create a Ray object in model space
(setq basePoint (vlax-3d-point 3 3 0)
secondPoint (vlax-3d-point 1 3 0))
(setq rayObj (vla-AddRay modelSpace basePoint secondPoint))
;; Create a polyline object in model space
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
(vlax-safearray-fill points '(3 7
9 2
3 5
(setq plineObj (vla-AddLightWeightPolyline modelSpace points))
(vla-put-Closed plineObj :vlax-true)
;; Create a line object in model space
(setq startPoint (vlax-3d-point 0 0 0)
endPoint (vlax-3d-point 2 2 0))
;; Create a circle object in model space
(setq centerPt (vlax-3d-point 20 30 0)
radius 3)
(setq circObj (vla-AddCircle modelSpace centerPt radius))
;; Create an ellipse object in model space
(setq center (vlax-3d-point 5 5 0)
majAxis (vlax-3d-point 10 20 0)
radRatio 0.3)
(setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
(vla-ZoomAll acadObj)
;; Iterate through the model space collection.
;; Collect the objects found into an array of objects
;; to be added to the selection set.
(setq ssobjs (vlax-make-safearray vlax-vbObject (cons 0 (- (vla-get-Count modelSpace) 1))))
(setq cnt 0)
(vlax-for each-item modelSpace
(vlax-safearray-put-element ssobjs cnt each-item)
(setq cnt (1+ cnt))
;; Add the array of objects to the selection set
(vla-AddItems ssetObj ssobjs)
(vla-Regen doc acActiveViewport)
GMT+8, 2026-10-30 01:34
