创建 3D 实体圆锥,其底位于 WCS 的 XY 平面上。 支持的平台:仅窗口 签名工 务 局: RetVal = object.AddCone(Center, BaseRadius, Height) 言论没有额外的评论。 例子工 务 局: Sub Example_AddCone()
' This example creates a cone in model space.
Dim coneObj As Acad3DSolid
Dim radius As Double
Dim center(0 To 2) As Double
Dim height As Double
' Define the cone
center(0) = 0#: center(1) = 0#: center(2) = 0#
radius = 5#
height = 20#
' Create the Cone (3DSolid) object in model space
Set coneObj = ThisDrawing.ModelSpace.AddCone(center, radius, height)
' Change the viewing direction of the viewport to better see the cone
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_AddCone()
;; This example creates a cone in model space.
;; Define the cone
(setq center (vlax-3d-point 0 0 0)
coneRadius 5
coneHeight 20)
;; Create the Cone (3DSolid) object in model space
(setq coneObj (vla-AddCone modelSpace center coneRadius coneHeight))
;; Change the viewing direction of the viewport to better see the cone
(setq NewDirection (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
(vla-ZoomAll acadObj)
GMT+8, 2026-10-29 18:32
